Ford Redtops Offset data from Greg's dvd
Im upgrading to the 30 lbs redtops injectors and I have all the data from greg's dvd, but my doubts comes from the offset values, because the table that come on the spread sheet and the values are a quite diferent than the tables on my 98 ls1
What do I need in order to get this rigth and working using these values?
They do not look out of line. There are major differnces @ 4-5v
but if system voltage is that low the car won't be running anyway.
The offset values are "quite different" from your stock injector offset values because the two injector designs are physically quite different. They might as well be apples and oranges, so one cannot expect them to have identical (or even similar) offsets unless it's by sheer coincidence. Please be sure to use ALL injector data as shown in the instructional DVD prior to solving for MAF and VE so that you'll get the best results for driveability and fuel control.
