Originally Posted by
AleroB888
I am running 28 lb. Trailblazer injectors, also. I have tried different fuel pressure settings, and adjusted the IFR accordingly. The lowest I used was around 23 with the stock 1999 regulator, which had a fuel pressure of about 38. For a fuel rail pressure of 45-48 I used an IFR of about 25.
I also tried fuel pressure set to 58-60, to get more output from the injectors, and a setting of 28 for the IFR produced average LTFTs close to zero. But drivability was not good with that high fuel pressure.
I can't explain the readings you got on that scan, though. It's as if there is some failure mode going on, or the scan is not reading correctly.
