I did an engine swap on my GF's 95 Cuttlass Supreme, the engine and trans are out of a 97GTP. The Engine harness is from a 98 Lumina 3.8N/A. Since I didn't want to re-pin a bunch of the PCM connectors to work with the 97PCM, I wanted to use a S/C 98-03PCM. I found one from a 98 Regal GS, however I came to find the Regal looks for a security signal from the BCM to activate the Injectors.
So, long story short, is there any way to disable the security on this PCM? Or fool it to believe there's a working BCM getting the proper security signals from the ignition switch?
The PCM it's running on right now is from a 99 Bonneville 3.8N/A. (Bonne's didn't have the BCM security stuff I suppose?)
Thanks in advance for any insight!!!
-Tim
