Results 1 to 3 of 3
Thread: 1998 Chevy vortec 350
    Mar 2008
    cheyenne
    27
    I picked up a 98 1500 and so I know it can be tuned but the parameters seem pretty sparse is that normal or has it kinda just been not fully unlocked. I also have a buddy that has a 97 1500 too and he was asking me could he put a 98 brain in it so I could tune it or is there something physically different that will not allow the 97 to be swapped.
    Senior Tuner Google's Avatar
    Sep 2010
    Saint Peters, Missouri
    1,303
    yes you can swap pcm's if your going to do a pcm swap then i.m.h.o. use a 0411 pcm and an 01 -02 o.s.
    you will have to do alot of work but it can be done.
    We Can Fix Your Bricked PCM Or Your YYYYYY OS ID
    Apr 2009
    609
    Do a search about the pcm swap on http://www.performancetrucks.net/forums/
    I know I came across the info when I was helping a friend with his 98. The Vortec motor is very limited in terms of how much power you can make due to the lift restrictions on the heads and no injector options for the central injection unit. Not saying it can't be done its just not cost effective in most cases.
    1997 Trans Am WS6 - LS1 swap - TR224 - Pacesetter Longtubes - Yank SS3600
    - 3.42 Moser 12 bolt - Wilwood Brakes - HP Tuners tuned - P1SC-1 Procharger
