This is just another goofy table I found that I don't understand. What's it do? And how do you use it?
Thanks,
-Robbie.
Thanks,
-Robbie.
618/618 motor
906/862 spray
Those are the timing numbers for max torque. Pretty handy for making advanced high octane tables they may or may not be on the verge of KR.
Makes a real good starting point.
That's odd, I always tune the High Octane Table and it follows it fine. Which table does it rely on most? This one or the High Octane?
Thanks,
-Robbie.
618/618 motor
906/862 spray
It's used to calculate torque output. Read the description, boy!
http://www.dsxtuning.com
Just say no to bull s***.
Description= read. So how do you tune with it? Or do you just set all numbers to thirty and it will run solely off the High Octane table I always noticed down low at WOT, the car simply does not listen to the High Octane, so I tried adjusting idle spark. That helped tons. But is still not perfect.... And the ECM seems slow to adjust timing when going up through the RPM band.... Is it because the High Octane and this conflict with one another?
618/618 motor
906/862 spray
That's another table I've never fully understood the purpose of myself. I usually leave it alone. But whenever I have a car that seems to be having trouble following my commands in the high octane table, I use that table, and it seems to do the trick.
Huh.... Well all in all I'd really like to understand the table more. It looks beneficial, especially in limiting horsepower if necessary.
618/618 motor
906/862 spray
It doesn't do anything. It is just used when the PCM calculates torque output.
Ok then Thanks Steck.
618/618 motor
906/862 spray
the PCM calculates how much torque the engine is making based on airflow and a few other things, the it compares the current timing to this max torque timing and reduces the calculated torque based on how close you are to this table.
This table plays no part in spark timing, just the torque calculation.
I count sheep in hex...
so then what does the torque calculation affect?
I have a question. if there are tables that don't affect anything meaningful in a tune like driveability, power, spark, airflow, fuel, throttle, etc or will fry the ecu if altered
why do we even have them in the editor? demand? why would customers want them in the Editor?
you know what I mean? I'm just wondering.
618/618 motor
906/862 spray
My Cranking table looks a whole lot different on my 08 Corvette.
the torque calculation mostly affects things relating to torque management,traction control system and also the transmission relies on a reasonably accurate engine torque value to go about its business.
if you ever did want to calibrate your engines torque efficiency this is the reference table. Some parameters are added because people see them in other software and MUST have them in HPT, sometimes without justification - the customer is always right you know
So wait, you guys are saying something like, if you make a datalog with the Calculated Torque Output, it references these timing numbers in a segment versus the airflow to figure the torque output via preset torque calculations? And if you change these numbers you change what the Calculated Torque shows, to represent a more accurate Torque reading.... Did I get that right?
618/618 motor
906/862 spray
Since you guys talking about calculated torque, how can get my 50% scaled tune to give proper torque reading? What I get now is 260 instead of 600. I know this is not actual torque readings but would be nice to get it back to normal reading.
the rest of the tables aren't shown that calculate the base torque figure, the base torque figure assumes MBT. But yes, if your actual timing numbers are below the MBT numbers and you lower the MBT numbers you should see an increase in calculated torque.
A lot of the base torque calculation references airflow, so if it's out then the torque will be out.
[email protected]
618/618 motor
906/862 spray
