Results 1 to 15 of 15
Thread: Tune Tips for Headers & CAI on a C6Z06 (almost in the 10's)
    Apr 2009
    6
    Just put Doug Thorley headers (no cats) & a Lingenfelter cold air intake w/100mm throttle body on my '06 C6 Z06. Car picked up 3 tenths & 3 mph in the 1/4 with the mods on the stock tune + the Lingenfelter high & low MAF tables. I have a Ragin Racin Punisher cam to put in over the winter at which time I'll have Bluecat here in KY do a professional tune, but in the short term with bolt ons I'm very close to running tens (11.13 @ 128). I have HP tuners & have already turned off rear O2's, COT & changed fan % temps. Anyone want to give me a few tips on adjusting timing & commanded AFR to try to pick up that extra tenth & get me in the 10's? Normally I would try to comb though the forum & research it myself, but I only have a few days here before my last track outing on Nov 7th.
    Thanks,
    Header
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Heck yeah I can help with timing! Throw up your Tune and I'll adjust it, and post up a Screen shot.
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    Dec 2008
    on the Dyno
    1,825
    What's up Header! Hope to see that thing busting Mikes ass Sunday! You two really need to get a lane with one another!
    Located in Central Kentucky
    ShorTuning
    Jun 2009
    42
    got any logs of your 1/4
    please post the log when you ht 10s
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by righton View Post
    Agreed.
    618/618 motor
    906/862 spray
    Apr 2009
    6
    Quote Originally Posted by LSxpwrdZ View Post
    Hey James, yeah Sunday's KYHP Shootout should be fun. Hope the track is prepped good & my stock LS7 clutch holds!
    Header
    Apr 2009
    6
    OK here's what I've done so far:
    Lingenfelter High & Low MAF tables
    Adjusted Fan temps for 160 deg stat
    COT - Disabled (no cats on car)
    Low Octane Timing Table - copied stock High Octane table
    IAT Spark Advance - zero'd from 104 deg & lower, lowered 113 deg to -2 & 122 deg to -4
    Knock Spark Retard - reduced Max Valid from 12 to 1.3 (GM factory value for '09 & up Z06's)
    Header
    Apr 2009
    6
    Decided to try the following for PE multiplier:
    0-5200 RPM = 1.176 (12.5 AFR)
    5500-8000 RPM = 1.157 (12.7 AFR)
    Header
    Feb 2010
    SLC, UT
    47
    Whats your timing like? On a intake/header tune most I've seen run about 24 degrees up top, with ~22 in 4800-5200.
    Advanced Tuner madvette08's Avatar
    Jan 2009
    Tampa, FL
    427
    How did go at the track?
    2008 Corvette A6 - Comp Cams 231/239 617/624 109 ICL 113 LSA, Patariot Extreme Dual Springs .660", Milled .30" Stock LS3 Heads, Mahle -4cc pistons, FTI 3600 Converter, 1 7/8 kooks cat-less 3 inch X-Pipe, air raid intake, ported TB, SLP Loudmouth I. 512hp/464tq
    2011 Ford Taurus SHO - stock with just a Tune
    Nov 2005
    Houston, TX
    3,968
    That (timing) and you need to be able to see what your actual AFR is. Set the PE table to your desired WOT AFR (12.5ish), strap it to the dyno and dial the MAF tables in with a wide band so you're AFR error is small. C6 Z's run very rich from the factory.
    Bill Winters
    Out of the LSx tuning game
    Jun 2008
    Charleston, SC
    969
    Quote Originally Posted by Header View Post
    Header
    i like to go 13.0 from 0-4000 , then 12.5 from 4000-5500, then 12.7 from 5500-8000 rpms
    -Carl
    Apr 2009
    6
    Quote Originally Posted by madvette08 View Post
    Got in a wreck with the vette on the way to the track so didn't get any runs.
    Header
    Advanced Tuner c.u's Avatar
    Jun 2010
    Eville, IN
    282
    that suck`s hope you and all are ok.
    Apr 2009
    6
    Yeah thankfully no one was hurt. Vette needs a new upper A arm, front bumper cover & drivers front fender.
    Header
