Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
Thread: how to actually adjust TPS voltage?
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    I'm ready to blow my damn brains out with this thing.
    I set up a graph to show the follower airflow against engine speed. The line that is steady represents 0 follower airflow at 900rpm, which is commanded idle. I played with it for a while, and it was pretty stable in neutral, although it'd still want to dip a lot. Follower would ALWAYS go away right before it dropped to idle speed, though. In gear, though, it's horrible. If you're just sitting still or at a really low roll, and you blip the throttle, it'll want to die. If you're going downhill, it'll stay running and return to idle perfect. On level ground, it's hit or miss. Going uphill, it dies every time.
    I adjusted the blade to get IAC counts down to 35-40 in park/neutral at operating temp, which is about 178º for this thing. I consequently reset the TPS so it was at about 0.61-0.63V at idle. TPS stays at 0% with key off, 0.4% with key on (no flickering to 0.8%).
    I moved the IAC vs. Effective Area table over to the right 3 cells just to make it slightly closer to actual airflow. I also set the base running airflow to exactly what the scanner was reporting, and then started screwing with startup airflow from there to get it to fire. When it's hot (again, 178º F), it fires up and idles perfect. However, apparently after it cooled down for a bit and the kid went to start it again, it was surging really bad on startup. I'm pretty sure that's because of the half-ass changes I made to startup properties in an attempt to get away from inflating the base running airflow to make it start.
    I'm going to try and get the car dropped off with me so I can just sit down with it and just get it done... but I'm kind of at a loss right now. I'm just shocked as to why this one is giving me so much bull shit. Injectors are Racetronix 42lb injectors, so I didn't have much info on them. The only mods on the car are the cam, which is a 227/231 0.617"/0.613" 113 LSA and headers (well, 4000 stall too). Yes, the car is in MAF only mode right now because it was originally a rush to get it ready to go to the track, so I was super pressed for time.
    Help me Obie-Wan, you're my only hope!... before I paint the walls.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    Need to either zero LTITs or log them and add STITs as well. At a glance, it looks like it needs more throttle follower. The amount added is VERY small. You can add a lot and use a more aggressive decay down low. It's all gone by 1500-1600 RPMs. The idea of it is to slow the RPM fall. The other reason to remove LTITs for the moment... If it moves to 2g negative at return to idle (from 0), it will pad things a bit. As it is, as soon as the TF decays, adaptive idle takes over at 1600 (throttle is closed, RPMS are in fall) but it doesn't 'know' that the car is in return to idle, it thinks idle. It just sees 1600 RPMs and instantly goes negative and applies the LTIT's learned negative value. This pulls the car down further, makes it fall faster. Log the IT's and you will see them act (update) the second that the TF is gone.
    Try this tweaked follower setup and use this cfg to log.
    Steve Williams
    TunedbyFrost.com
    Jan 2006
    Richmond VA
    1,950
    The joy of IAC cars.... if you are used to DBW, you will grow to despise the IAC.
    Steve Williams
    TunedbyFrost.com
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by Frost View Post
    The LT1 IAC cars aren't near as finicky. As long as they have enough base air and you can get most of it going through the manifold idle circuits, they are fairly tolerant.
    Jaime
    Mar 2008
    St. Louis, MO
    4,859
    I'll try the changes you made. This is the first cable throttle that is pissing me off beyond belief. I'm beginning to wonder if the IAC is sticking, because it always seems very slow to respond compared to every other car I've done.
  6. #26
    Senior Tuner Google's Avatar
    Sep 2010
    Saint Peters, Missouri
    1,303
    one thing that i seen was that when you blip the throttle the iac counts drop from 92 to 69 which makes me think that the stit is adding airflow at idle and when you blip the throttle the stit go to 0.00 and when it hits adaptive idle the stit's can not add it back in fast enough. your max ltit in p/n and in gear is set to 0.50 log your stit and ltit and set your ltit max to 3.00 to 5.00 untill you get it dialed in. just trying to help you out
    We Can Fix Your Bricked PCM Or Your YYYYYY OS ID
  7. #27
    Mar 2008
    St. Louis, MO
    4,859
    So I tried the file from Frost and it was even worse. It didn't even try to stay running. I noticed that if I forced the IAC to 120 counts for a short period when revving, it'd recover. I ended up multiplying the follower airflow table by 2, and then multiplied the decay by 2. I also added a 0.2 delay at 0mph. I kept this delay up to about 10mph. The follower doesn't decay out before returning to idle, but it doesn't die. It comes down to about 1050rpm and sits there for about a half second, and then sets down to idle. It still isn't perfect, and will still die on rare occasions. It just wants to die so freaking fast, and it doesn't make sense. The blade is cracked open pretty far yet it still is super sensitive to running out of air. I'm going to keep playing with it. It seems like it does best with a huuuuuge cushion of tons of airflow, and then take it out quickly. I'm just absolutely puzzled as to why a small cam needs the blade cracked open so damn much to get IAC counts down.
  8. #28
    Nov 2007
    MI
    686
    what ever happened here?
    2018 Camaro SS, Maggie 2650, 103 TB, Big Gulp, E85
  9. #29
    Mar 2008
    St. Louis, MO
    4,859
    I found a method that works for me to dial it all in.
  10. #30
    Advanced Tuner Pulse_GTO's Avatar
    Apr 2008
    329
    Care to share?
  11. #31
    Mar 2008
    St. Louis, MO
    4,859
    It's not really easy to put into words. You just have to play with the throttle follower settings to find a happy medium of setting the idle down from various RPM blips.
  12. #32
    Nov 2007
    MI
    686
    can you be more specific? was it the follower?
  13. #33
    Nov 2007
    MI
    686
    ah, i see thats what i figured
  14. #34
    Advanced Tuner JamesLinder's Avatar
    Jan 2011
    Bella Vista, AR
    363
    Throttle Position Sensor Issues
    I was having problems with TPS not reading correctly, which of course will not allow the start-up idle routines
    in the PCM to operate correctly among other problems this causes since quite a few PCM functions require TPS
    position as an input parameter.
    What I discovered yesterday (Dec 3, 2013) with my 2000 SS Camaro (OEM PCM, throttle cable IAC-equipped
    throttle body) is that even if you unplug the TPS harness and turn the key on, turn key off, reconnect the TPS
    harness that this does not necessarily reset the TPS to zero; in fact, it did nothing. From readings on HP Tuners
    scanner it was obvious that the TPS sensor was sending pure crap to the PCM, and when the throttle was closed
    it typically was at 2% and at times even higher.
    Once I removed the 2 PCM fuses under the hood (which has same affect as removing battery cable) then the
    TPS sensor finally returned to the state required for it to relearn closed throttle as zero % TPS and for it to of
    course completely relearn everything to do with idle air trims. This completely solved the problems I was having.
    Evidently, when tuning, especially if changing TB blade location with the adjusting screw, it is not rare for the
    TPS sensor calibration to become corrupted, or in other words, FUBAR. You can tell when this is the case
    because the scanner will yield erratic TPS readings when you operate the gas pedal through its full range with
    the ignition key on and the motor not running. Basically the readings you will see are completely random and
    make no logical sense at all.
    When your TPS sensor loses its mind like this, there is nothing you can do other than disconnect power to the PCM
    to eliminate the problem. You will probably think you have a bad sensor because the readings are so ridiculous,
    however it has just lost the ability to communicate any meaningful readings to your PCM.
  15. #35
    Old thread same problem
    I am having the exact same issue MY GOD is it annoying. I did the battery reset i ran new grounds to pcm. cold no issue. Heat soak start tps reads .8 percent and starts idling all kinds of goofy then it will idle fine then it will move up and down a few hundred rpm. unplug tps settles down exactly how i want it to idle.
    And i feel the same way ready to drive this damn thing off a cliff.
  16. #36
    Mar 2008
    St. Louis, MO
    4,859
    I've had a couple cars where all new wiring had to be run in order to get stable tps voltage.
  17. #37
    Oct 2014
    48
    I had this same issue yesterday. Thank you soooo much for posting your experiences DSteck. After fighting the high idle, rich AFR and inability to reset the TPS percentage. I cussed, closed the hood and came inside the house to scan the internet. I found 100's of threads but yours had the solution. Getting the TPS voltage from .4 to .63 allowed me to reset the TPS % (FINALLY!). Once it was reset and I started the car, it idled at the commanded 750 RPM (as opposed to 1,250), the AFR went from pig rich (10.x) to 12.x(yes, still rich, but now I can work on that).
    Thanks again for putting your experience out here.
    David Wilson
    96 Z28 - Blueprinted Forged 5.3, PRS Stage 2.5 heads, Isky Triple 12 cam, PT7675 Turbo, 127# Bosch Inj, Transbraked 3800 stall TH350
  18. #38
    565
    is there a table for setting the maximum allowed tps % for idle controls?
  19. #39
    565
    ok so no one knows.
  20. #40
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by reubone View Post
    ok so no one knows.
    There are, in some cases, but you haven't provided any information on your application or a sample file to help with.
    Jaime
