I have been logging on my stock 2010 Camaro trying to make sure I know what I'm doing in preperation for a blower next week. Ran it in closed loop and tweeked on the MAF about 4% from 3000 hz and up. LT and ST fuel trims were just about all 0's now. Hooked up my AEM wb and was doing some logs in what I thought was open loop to make sure it was reading normal. I had unpluged and removed the drivers side front o2 sensor to install my wb. I thought in OL that would be ok. Logged my 10 mile trip home last night and noticed afterward that about 4 min (frame 4153) into the log it had 2.3% STFT on bank 1. It goes back to 0 WOT but then comes back at cruise. I set the CL enable temp and o2 readiness temp to 285. I set the LTFT enable learn temp to 285. DFCO temp enable to 285. COT to disable. I set all 4 OL EQ ratio tables to 1.00. Does that sound correct?? Hopefully someone can tell me what is going on.
thanks
Stan
