Results 1 to 8 of 8
Thread: Traction Control issues and P0106?????
    Jul 2008
    1
    Just like the title says I need some help here. I have axcess to HP tuners and was looking over somethings. I have had the P0106 Code come on for like the three years know the tuner never seems to find any issues with the code. I just want the code gone for know I have disabled the SES light for the code but I am looking for a permant fix to the problem. I have also been experiencing issues with my traction control it seems to control its own mind and I cant figure it out. There has to be something in the tune that cause it to come on and off on its own. This is all on my own 2002 Camaro SS by the way.
    Thanks for any help, it is greatly appreciated.
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    If your idle Map Kpa exceeds 62 kpa, then you need to raise the P0106 Error Map Calculated Max table.
    Russ Kemp
    Aug 2010
    10
    russ k i sent you a pm but your box is full.
    Aug 2010
    212
    Thanks Russ K That is exactly what I did and I don't have any problems with the car at all.
    Apr 2007
    Atlantic City, NJ
    33
    I'm sorry for raising the dead, but I have this very problem and my Idle MAP is in the high 60's.
    However, I cannot for the life of me find this setting to change. My computer is a 2000 OS though, does it have the feature the 2002 has?
    2002 T/A Firehawk : bilstein/eibach package, auburn
    TSP 404 Iron Long block with PRC stage 3 6.0L heads, Texas Giant cam, Fast90, NW90, Kooks 1-7/8", Kooks ORY, Magnaflow/cutout, Spec 2+, Spec Billet Flywheel, Racetronix 37# injectors
    Strano Springs, Koni Adjustables
    BMR: Q Arm, boxed LCA, PHR, STB.
    Advanced Tuner robbyredneck's Avatar
    Jan 2010
    fingerlakes ny
    356
    should be engine diagnostics>airflow>map sensor>p0106 map max
    04 6.0 silvy china turbo
    87 gn
    03 stroker evo ww
    00 ss camaro
    Apr 2007
    Atlantic City, NJ
    33
    yea mine doesn't show it. I am in advanced mode, so thats not the problem.
    mine only shows the following:
    MAF fail high freq
    Maximum delta airflow - P0101 Error
    Dec 2005
    Regina, Sask.
    4,214
    I would send your file to support to get the table added.
    Russ Kemp
