Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Compressions vs timing
    Feb 2010
    SLC, UT
    47
    Friend just had his heads milled to raise his LS7 compression from 11 to 11.6. What would be a good start place to adjust his tune to account for the added compression. I took 2 degrees out of the high load cells of the high octane map. Good starting place or should I pull more? Anything else that may need adjusted when raising compression?
    Jun 2007
    Close to my Z06
    271
    At you getting any knock with new comp?
    Feb 2010
    SLC, UT
    47
    Yah. Pulled 2 degrees out, did one little pull and saw 1-2 degrees of KR. We didn't beat on it too hard because he wanted to heat cycle the valve springs and check stuff. Tonight we will do more. Car is a ragin racing lethal cam (232/250 .660 lift) with WCCH milled heads, kooks 1 7/8", no cats, haltech intake, fast 102 manifold.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    Are you seeing burst knock or actual knock? I've found that sometimes, burst knock happens during a WOT pull, and a lot of people mistake it for actual knock.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Feb 2010
    SLC, UT
    47
    DSteck, can you explain how I would tell the difference?
    Right now compared to my car which has a bigger cam, this car surges/chugs a lot more at low throttle. Got to play with that and see if I can get it better. No reason it shouldn't drive better then my car.
    Quote Originally Posted by Unreal View Post
    Also Curious
    2009 Crystal Red CTS-V A6
    Hennessey CAI, Hennessey 2.55 Upper
    2005 Phantom Black GTO M6
    All stock other than forged shortblock, braided clutch lines, and bushings. CAR IS FOR SALE For sale, $14,000, 65k miles.
    Having a shop build your car is like having a porn star screw your wife. Pick up a chiltons manual and a wrench and learn something.
    Feb 2010
    SLC, UT
    47
    Going to play with it more tonight. Here is the current tune to peak at.
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    I would like to know as well how to differentiate between Knock and Burst Knock, and if you have Burst knock, how do you correct it?
    618/618 motor
    906/862 spray
    Feb 2010
    SLC, UT
    47
    Car runs great. Didn't get WOT done because the wideband is in my car but part throttle, idle, and everything is great.
    Current tune, haven't touched WOT.
    Aug 2010
    Roswell, N.M.
    1,956
    Nevermind, for tuning purposes, or if you're like me, just zero out the BKR. All it is is a prediction factor for knock, not true knock and if you zero this table out then the ECM will reference the High and Low Octane tables. Remember boys and girls, it takes the ECM a second to switch from the Idle Spark Advance table to High Octane Spark Advance for those of you who are getting KR if you mash the gas at idle and just can't make it go away.
    618/618 motor
    906/862 spray
    Dec 2005
    Verona, WI
    144
    You should be able to log the actual PID for burst knock.
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by Nick 2K2 SS View Post
    Yeah you can, but why? It annoys me because it's learn up/down feature constantly plays with the timing. Hence not have a smooth timing log at WOT. (At least that's what it does to me.)
    618/618 motor
    906/862 spray
    Mar 2008
    St. Louis, MO
    4,860
    Pretty sure burst knock doesn't get applied to any learn pattern.
    You can log Total Knock Retard and Knock Retard. If Total Knock Retard has a value, but Knock Retard is zero... then it's burst knock pulling timing.
    Aug 2010
    Roswell, N.M.
    1,956
    If you're timing table looked as goofy as mine, yes it would. I just went out and tried it with it off, and had a perfect timing log following exactly what my High Octane Table was. Turned it back on and it jumped around between 9 and 13 even though it's supposed to run a flat 15 degrees where the BKR was screwing around at. And it was doing it for no obvious reason despite the fact I'm running 96 Octane.
    618/618 motor
    906/862 spray
    Mar 2008
    St. Louis, MO
    4,860
    Quote Originally Posted by IDRIVEAG8GT View Post
    That doesn't mean it was learned.
    Mar 2009
    32
    What are the Burst Learn tables for then?
    Mar 2008
    St. Louis, MO
    4,860
    Quote Originally Posted by DrBoost View Post
    Hell if I know, but I never see burst knock stick around. When it shows up during WOT, it shows up as little blips of 0.5ยบ or so, and instantly goes away. Do another pull, and the pattern is totally different. Just zero out burst knock and move on with life.
    Feb 2010
    SLC, UT
    47
    Dsteck, my car does that sometimes. Just small blips of .2-.5. Is burst knock something that should be turned off for tuning only or all the time. I've just ignored the .2-.5 KR that happens maybe 1 out of 10 pulls. Normally when the tires are spinning.
    Mar 2008
    St. Louis, MO
    4,860
    I will either cut the burst knock table in half or shift it over one cell, which usually helps to get rid of that crap. Sometimes I just eliminate burst knock completely, though.
    Dec 2007
    776
    Burst knock learn works to make burst knock retard more aggressive if real knock is still detected during BKR and less agressive if no real knock is detected. It optimises knock control at the extremes when the factory runs the engines on the edge of knock.
    BK is probably more applicable for factory tunes/cars than specifically tuned cars/trucks. Though lets face it, if GM went to the effort to put it in there, it does achieve something relevant.
