Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: "LS3" 3 bar map sensor 12592525 on gen III?
    Tuner in Training Gonoma's Avatar
    Sep 2010
    Greenville, SC area
    33
    Posted in an existing thread in the gen 4 section but they weren't much help. I am building a 02 lq4 with LSA heads and a ls3 intake and was wondering if the 12592525 3 bar sensor off the LS9 would be a plug and play (with the correct harness) using the custom 3 bar SD OS on a 02 silverado pcm. Or does anyone know where i could find out?
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    http://www.hptuners.com/forum/showpo...72&postcount=3
    Looks like the post was under Gen IV, but it still applies. If you can change the offset and linear values for the MAP sensor in a Gen III, then you can use the 2525 MAP sensor, but for some reason, I'm thinking you can't enter a negative offset value in the Gen IIIs. I could be totally wrong.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Sep 2010
    Greenville, SC area
    33
    you're right. I automatically changes to 0.00 is there any way HP can fix that?
    Jan 2011
    6
    bringing this back... did you ever figure it out...
    can this sensor be used on the gen3 stuff?
    ive got an 03 lq4 computer that id like to use for >15 psi
    thanks
    Jan 2011
    6
    bump... is this sensor ok to use on a gen 3 truck pcm?
    Mar 2013
    6
    Bump! Also interested
    Feb 2006
    Buckingham (Doylestown) PA
    216
    Another bump to find out how to use the LS9 sensor in a Gen 3 02-Fbody.
    2000 T/A - Thompson Motorsports 416ls3, F1A procharger, HP tuned. Just a couple psi of boost.
    2013 Mercedes C350, wish HPtuners worked.
    Mar 2008
    St. Louis, MO
    4,859
    You don't, unless you want the manifold pressure readings to be inaccurate.
    Jun 2012
    10
    What sensor are people using for 3 bar? Regular gm brick?
    lol, I just bought the zr1 3 bar map.... looks like I just wasted some money.
    I've got a 01' silverado 5.3
    Mar 2008
    St. Louis, MO
    4,859
    They're using the GM brick or the Duramax sensor.
    Jun 2012
    10
    Probably use the brick. You have any idea what the linear and offset are for those?
    Mar 2008
    St. Louis, MO
    4,859
    Not off the top of my head. :-/
    Jun 2012
    10
    Apr 2006
    western NY
    339
    Why cant i just send a request to support to change the Map Sensor offset so it can have negative values for the Pcms that cannot be adjusted to use sensors using negative values
    2000 Firebird,2002 O.S.,LQ4 370,Borg Warner S475,truck mani.,Eagle crank,Callies Compstar Rods,Wiseco-11 4.030 pistons 9.4:1 comp.,LS3CNC heads,LS3 intake,NW92mm throttle body,ID1000 injectors,BTR trunion upgrade,LJMS STG3 cam,LS7 Lifters,ARP Studs-bolts,Frozen Boost A to W intercooler,JGS 60MM BOV,2 40mmJGS Wastegates,4L80E trans wth segment swap,CircleD 3400 single disk,MOSER 12 3.31gears ,BMR K-Mem.,2 Walboro 450 pumps,Returnstyle fuelsystem MAGNAFUEL regulator.
    LS1Tech sig KRAZY K 2000 TA
    Mar 2008
    St. Louis, MO
    4,859
    Quote Originally Posted by Throttle View Post
    Because it's not up to them on what values can be entered.
    we're looking into fixing this for LS1 PCMs. The MAP Linear and Offset will be in the editor for the stock OS and also fixup the negative thing.
    I count sheep in hex...
    Mar 2008
    St. Louis, MO
    4,859
    Quote Originally Posted by Chris@HPTuners View Post
    Do you have to do that through a patch?
    Apr 2006
    western NY
    339
    That would be awesome for this fix!!
    Advanced Tuner robbyredneck's Avatar
    Jan 2010
    fingerlakes ny
    356
    couple of years late but it would be awesome
    04 6.0 silvy china turbo
    87 gn
    03 stroker evo ww
    00 ss camaro
    Apr 2006
    western NY
    339
    i have held off on ordering a Map sensor because they said maybe!,But when the machine shop is done balancing and boring my block somethings gotta happen.
