Results 1 to 7 of 7
Thread: Startup is fine, pull away and car goes lean and misfires
    Aug 2006
    39
    I've been battling some tuning issues recently. I have been having a situation that I will start the car and back out of the driveway in 20-30 seconds. My driveway is small and on a slight incline so backing out the car is in neutral. I go to put the car into gear and pull away and the car pegs the WB lean and misfires like crazy. It will continue to do this until, from what I assume, the car reaches a certain ECT?
    What causes the car to behave like this? The fact that it is in OL at that point? Can I fix it?
    I am attaching a scan to show how the car starts and idles fine. I played with the afterstart enrich to see if that helped the situation at all. All it did was fatten the car up. As soon as I put it in gear and released the clutch- it went lean still.
    Basic mods are: heads/cam, ls6 intake, LT's/ORY/catback, 30# red top skinnys
    Thanks for the help!
    '98 T/A M6 Pics/Mods
    '99 Z28 M6 SOLD
    Aug 2006
    39
    No help?
    '99 Z28 M6 SOLD
    Jan 2006
    305
    By the looks of your tune, I think you are in closed loop. Your closed loop enable temp is 93 degrees. Have you tried working on your tune in OL?
    Closed loop Enable is stock 34C.
    VE is a mess i some areas. If you canĀ“t see it - READ MORE
    MAF could look smoother.
    Idle sparks looks better than Main that can be smoother.
    You need to get VE and MAF 99% sorted before adressing your energy in other areas. If these are wrong computer is trying to correct things where input values are wrong from the beginning.
    There is no problem running in open loop if VE and MAF are correct...
    Reset all parameters to stock except injector data and MAF/VE and then retune with proper method. It will work...
    C5-2000 MN6 LS2 block Tony Mamo FAST90+Ported LS2 TB 100mm MAF AFR 205 59cc CompCam 921 Yalla Terra G5X1 LG Pro Headers LG G2+T1 Chassie LG ducts MOVIT brakes - HPT&NGK AFX
    //Sweden
    Advanced Tuner 69lt1bird's Avatar
    Oct 2007
    983
    Grab the guide in my sig, it should help you get started with the basics.
    Free HP Tuners Beginners Tuning Guide
    LS1 Tuning Guide
    Michigan Snowmobiler
    1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
    Aug 2006
    39
    I will start tuning the VE and MAF then....I have your guide printed Jeff. Thanks
    Is this what is causing the car to go really lean?
    When I was saying OL, the car was in fact in OL because it was colder than the enable temp. I was not implying that my car was in OL all the time.
    '99 Z28 M6 SOLD
    Oct 2007
    983
    It could be. You need to tune with the PCM forced into open loop, that takes all of the fuel adder variables out of the equation and will help get the VE and MAF as accurate as possible. Just take your time and be patient. Steady throttle movements and steady speeds is critical.
    LS1 Tuning Guide
