Hey guys im trying to get more power what should i do for torque management? Attached is my tune up. I changed my enrichment rate, enable rpm, delay rpm, and torque management in trans settings.
Take a look at these:
need more low end
truck is weak off the line
07 Avalanche Exhaust & CAI
i already read both of those. played with PE and decay and found it burned fuel really really bad. where should i go to remove most of the TM? thanks
Well don't go setting your Enrichment rate all the way up to 2. 1.5 is good. When changing your PE Enable versus TPS, make sure you don't set it down into normal driving throttle percentages or else it will burn an ass load of fuel and you won't ever have an OL/CL oscilation. Adjust timing accordingly. Timing makes all the differences for power. Make sure your MAF is adjusted correctly too. Do you have a Wideband?
618/618 motor
906/862 spray
Unless there is a change in logic between the years there will literally be no difference between 1.5 and 2 or 1. If you are currently at an EQ ratio of 1.0 (stoich) and you stomp the pedal, the enrichment rate you set will be added every 12.5ms (again assuming this hasn't sped up in later models) until you reach your target. So, assuming you are targeting 1.15 or so you will almost instantly (well 12.5ms later) be there because you only 0.15 to go assuming your other triggers are met ie MAP, TPS, delay time, delay RPM if set.
I hope I explained that clearly enough.
So, as long as you don't have it set like some trucks at 0.0xx then 1 is effectively instant and no different to 1.5 or 2 or 20.
i dont have a wideband. when you say MAF adjusted properly what do you mean and where should i adjust my timing? im new at this (obviously) but have been reading lots and just find its hard to find what exactly does what etc.
anyway thanks for the tips. much appreciated.
All in all so far as the new Gen IV stuff goes, as I understand it, 1 is equivalent to Base Factor with no Multiplication. Essentially 12.5Ms later you come up with the same exact enrichment value as you started with. But now if you go above 1, you multiply your standard Stoich value and with this the ECM has modified the oncoming fuel versus the time that it gets there. On your standard block cars if you watch one that has their enrichment rate set up to 2, when you mash the gas off idle they will hesitate slightly longer and puff black smoke everytime, versus the same car with a 1.5 or 1 Enrichment rate, as the 2 Enrichment rate value Over-Enriches, causing a Rich condition until it leans itself and burns excessive fuel.
618/618 motor
906/862 spray
I suggest getting one, but that's if you wanna get real Nitty Gritty with your tune, especially at WOT, and if you have the money to spend. Now, I didn't even look at your tune, however so far as timing goes..... down low 16 is a good starting point for a 9:0:1 Compression ratio engine running 87 or better Octane, and probably upwards of 23 in higher RPM. You can add as necessary for more power or if you're running fuel with bigger bangification and slower burn rates, but be careful. Knock is a killer. Fueling is the second thing. Read more posts to adjust overall fueling. Don't go dangerously lean in search of 2 more horsepower. It's not worth it. Study up on Transient fuel. There's alot of power to be unlocked by tweaking those tables. Adjusting MAF, meaning for you to watch your Long Term Fuel Trims. If they are off then your MAF needs tweaking (I.E. LT is +3 then you add 3 percent to the corresponding cell in your MAF Hz table to correct the lean condition) When making a log, Make sure you are scanning with MAF Hz installed into your Main Table feature. An Accurate MAF = More overall horsepower, more smoothness in acceleration transition, and less general ECM confusion.
618/618 motor
906/862 spray
Oh! and on your TM, that'll be found underneath your Transmission section. If you're running a 6L trans, then you have like 50 different tables to play with. :O Are you AWD?
618/618 motor
906/862 spray
no not AWD. just 4wd and its the 6.0l
thanks for all the help ill see what i can do. takes a while to learn thats forsure but enjoable none the less.
thanks
also a dumb question but where will i find the timing? thanks
618/618 motor
906/862 spray
618/618 motor
906/862 spray
