I went yesterday to tune a truck that my buddy did a motor swap in and we're having a little issue that I can't put my finger on. Here's the setup:
2004 V6 Silverado
Swapped to a LQ4/L92 setup
Throttle body works just fine
SVO Green Top injectors
4L80E Segment swap on V8 OS
Basically what's happening is injectors 2/4/5 aren't doing anything. I know the injectors are fine, and the stock L92 injectors did the same thing before I swapped them for 42's that I know work. I checked the injector clips and they're all soldered really well and the leads have continuity all the way to the PCM connectors. They're also getting a good switched 12v power to the connector. With the motor idling (like shit) you can just unplug those injector clips and it doesn't effect the motor. If you unplug the ones that are firing 1/3/7/6/8 it'll make the motor stumble and die. I haven't used a noid light, but using the multimeter I'm not getting a ground pulse to the clips that aren't working but I am getting a pulse to the ones that are working.
I figured okay maybe it's just a bad PCM so I hooked up a spare one I had and did a write entire with the tune file. Same problem with the same cylinders. Is it possible that the OS could be corrupt and not telling the injectors to fire?
The V8 base file that I got segment swapped was from another customer's truck that was a 2004 V8 etc.
I don't have my laptop with me, but I will post the tune file later.
Also, one thing that's strange is the gas gauge shows exactly the opposite of what's in the tank. Full tank shows empty on gauge, empty tank shows full on gauge. Never had that problem on my buddy's 2006 V6 truck that we put an LS2 into. Maybe that's a sign that something is up?
Thanks for reading my novel lol, just need some ideas on how to trace/diagnose this problem.
