Results 1 to 2 of 2
Thread: Cant get it
    Sep 2010
    colorado springs
    20
    Cant get it
    Ok guys I bought a computer & harness off ebay. It came all set to go( called hotrod set up) .But I cant get it to tune properly.It was all set up for open loop only when I got the system . It runs rich at idle (11. to 12AFR 1& lean WHEN YOU GIVE IT GAS 18 TO 20AFR iVE TRYED TO REPROGRAM THE MASS AIR FLOW SYSTEM WITH NO CHANGE . .,it has no tps reading .I thank it my be the wrong computer for the harness .the harness is all set up for the ls1 engine with cable throttle.It says when I put the vin into hp edit that the computer is for a 2002 zo6 corvette with fly by wire throttle.Do I need to get a earlier computer to make it all work or can I trick this computer? THANKS Eddie
    Apr 2009
    17
    We can flash that computer for a 2002 camaro that should help give me a call chis cbmmotorsports 909-291-7550
