Results 1 to 10 of 10
Thread: Net Framework
    Tuner in Training sreve's Avatar
    Jun 2008
    35
    Net Framework
    Hello
    I just purchased HPT and am having an issue with the install.
    It says i need net framework 2.0 to install. I already have Versions
    1, 2, 3, 3.5, 4 i cannot uninstall the ones i have it won't let me (see pic)
    Is there some kind of work around for this?
    Feb 2007
    San Antonio, TX
    1,255
    On your login page it should load with the screen to download the VCM Suite 2.22 and install the .Net Framework 2.0.
    Janky Monkey Tuning
    Call or PM for tuning solutions.
    Cell 210-954-4985
    Wrench turning provided by 2 Tightwads Racing.
    Tune your own? Start here ----> Open Editor ---> Hit F1...READ!
    READ SOME MORE (Thank username 69Lt1bird): http://ls1tuningguide.com/
    Still lost? Consult a Pro!
    www.thetuningschool.com
    www.calibratedsuccess.com
    www.tunedbyfrost.com
    Jun 2008
    35
    correct
    Net framework won't install I have a newer version than the one HPT requires
    and i cannot remove it in add and remove programs
    Feb 2007
    San Antonio, TX
    1,255
    I have the newer .Net Framework as well. Running windows 7 Ultimate on both machines. Only problem I've even run into upon new install on new computer was the MPVI A/B drivers not recognizing. Can you post a screen shot of the error message HPT software is giving you?
    Janky Monkey Tuning
    Cell 210-954-4985
    Jun 2008
    35
    Screen shot attached
    I'm running XP Pro SP3
    Jun 2008
    35
    So i tried to put it a desktop to run the program
    HPT setup says to install Net framework 2.0
    Windows 7 Ultimate
    Error: This product already installed as part of the operating system
    See attached pic
    Apr 2010
    18
    Using the version with the .net checks removed in the thread below may solve the problem.
    http://www.hptuners.com/forum/showthread.php?t=30495
    Feb 2007
    San Antonio, TX
    1,255
    Taken from above link:
    If you run Win7 you need to right click the exe files ("VCM Editor.exe" and "VCM Scanner.exe" and run it in "windows XP SP3" compatibility mode. That fixes the issue above when you try to open or save files.
    OR Email:
    [email protected] with your serial number for access to the BETA 2.23 which doesn't have this issue at all.
    Janky Monkey Tuning
    Cell 210-954-4985
    28,247
    As Jeremy stated you need to use the 2.22 with the net framework checks removed posted here http://www.hptuners.com/forum/showthread.php?t=30495
    The beta software also has the checks removed as well but is not necessity.
    Jun 2008
    35
    Thank guys i,m up and running now. I did search but i missed the .net checks removed
    version.
    Thanks Again
