Page 2 of 8 FirstFirst 123456 ... LastLast
Results 21 to 40 of 143
Thread: 6L80E TCC Apply Issue Fixed!!!
    Advanced Tuner Pro Street's Avatar
    806
    244
    This will be great!!!
    2018 GMC Denali A8 6.2L
    2016 CTS-V
    2016 C7 Z06 A8
    2016 C7 Z06/Z07 A8 vert
    2015 Chevy SS 6.2 LS3 A6
    1996 Impala SS LT1 CAI
    1995 Chevy 1500 5.3 CAI Z06 cam
    1957 Chevy vert
    Feb 2006
    Rancho Santa Margarita, CA
    905
    Quote Originally Posted by Chris@HPTuners View Post
    ok here's a list of what i've found and will be added next week:
    TCC Desired Slip AC Off vs. Gear
    Min Desired Slip AC On
    Use DoD Slip
    TCC Desired Slip DoD vs. Gear
    Desired Slip DoD Off Transition
    Desired Slip DoD On Transition
    High Speed Lock Enable
    High Speed Lock Disable
    TCC Adapt:
    Trans Temp Min
    Trans Temp Max
    TPS Min
    TPS Max
    Torque Min
    Torque Max
    VSS Min
    VSS Max
    Adapt Min Pressure
    Adapt Max Pressure
    Adapt Cell Preload Pressures
    Adapt Cell Torque Breakpoints
    TCC Max Pressure
    Would you give us a quick briefing on which of this tables can be zero out to prevent the 100rpm slip that was mentioned before ?
    Quote Originally Posted by bluegoat06 View Post
    Desired slip tables
    I count sheep in hex...
    Feb 2006
    905
    Thanks a lot Chris.
  6. #26
    May 2010
    6
    Use DoD Slip
    TCC Adapt:
    Trans Temp Min
    Trans Temp Max
    TPS Min
    TPS Max
    Torque Min
    Torque Max
    VSS Min
    VSS Max
    Adapt Min Pressure
    Adapt Max Pressure
    TCC Max Pressure
    I'll have to remember to ask Bill for the update
    Black 09 G8 GT Black 09 G8 GT RPM tuned, Baby cam, Vararam, Kooks LTH, Stock muffs, Circle D stall, RPM ported TB and Intake, UDP, PCM for less trans cooler,BMR toe rods trailing arms and diff bushings, First G8 GT with a Camaro 3.45 diff swap(as far as I know)421whp 384wtq [email protected] pre gear swap
  7. #27
    Jan 2010
    30
    Desired slip tables
    SWEET!!! I will be eagerly awaiting this. I think i've noticed this "100 rpm slip" while coasting downhill at ~50 mph. This will be a great fix, especially if it helps a little with fuel mileage! Good job guys!
    '09 MGM G8 GT
  8. #28
    the new params have been added, they will be in the next release. Please contact support to be notified.
  9. #29
    Oct 2010
    9
    Chris, do you know when the download will be available
    Scott (Retired Navy)
    Paralyzed Triathlete
    2010 Camaro 12.35 110.73 1.65 60ft
    Mongillo Motors
  10. #30
    28,285
    Probably a week or so.
  11. #31
    Oct 2010
    9
    Thanks Bill.......Cant wait.......
    Mongillo Motors
  12. #32
    Sep 2007
    393
    Speaking of a new beta, have you fixed the bug yet regarding the line pressure table for the 6L80? It's the one where if you change any values in the Trans->Auto Shift Properties->Shift Pressure->Shift Pressure Other->Max Line Pressure table it stores incorrect values and you run the risk of blowing your trans?
  13. #33
    28,285
    Quote Originally Posted by thesubfloor View Post
    Dunno Chris I can't find this bug as being reported, email support with what information you have or provided previously as I don't find it in my email's with you.
  14. #34
    Sep 2007
    393
    I found our e-mail conversion from July 9th and just forwarded it back to you.
  15. #35
    28,285
    Thanks, I've resent it. Its a software design bug, not an engineering bug so Chris really has nothing to do with it.
  16. #36
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Hurry up! I want this
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
  17. #37
    Oct 2010
    9
    Chris, Bill, is it in downloadable format yet?
    Mongillo Motors
  18. #38
    28,285
    not to my knowledge.
  19. #39
    Oct 2010
    9
    ttt
    Mongillo Motors
  20. #40
    Jul 2009
    20
    da bump...
