Got a problem that I don't know where to look. '00 SS, stock OS, heads,cam screened truck MAF with integrated IAT sensor. After sitting still, engine off, for a few min, upon restart the IAT reads from 120s to 140s. I understand this heatsoak, but the issue is after approx 5sec or so, the AFR goes lean to the degree of 18-20/1. I realize the computer is prolly figuring on less air coming in due to the high temp an fueling accordingly but there has to be a table to compensate for this. BTW, the MAF is disabled during this time due to VE calibrating. Will the MAF correct this when it's enabled, and if so, how do the SD guys get around this? May be a simple fix, but I'm still learning. Thanks for any help.
