Hey Bill, thanks for the reply. I had the EIO LM2 equation setup at volts/.625 +13.1, this read correctly at idle, but was 1 point off at WOT range (13.0 range). Stoich is defined as 14.68 in the tune and I believe 14.7 in the WB (I didn't configure it). I believe I am going to use the VCM controls to command around 13.0 and see how the WB reacts/matches.
I was having a brain fart that day, lol. In my table I was logging AFR error (PID from hp tuners) and I was getting the percent difference in the scanner, but I couldn't figure out how to in the histogram. Should have just put that PID into a histogram, DUH.Also there is no reason to create your own AFR Error PID when using EIO/Pro. Once you have an air fuel ratio sensor defined (WB PID) it uses that for SENS.120 (AFR) and the built in AFR Error PID compares that to SENS.121 (commanded AFR) and give you the AFR error.
