Thread: MAP won't change
    Jul 2010
    Milford, CT
    29
    MAP won't change
    In my latest log, my MAP stayed at 92.0 the entire run. Is this a sensor issue, or something in cfg?
    Advanced Tuner umrjmac's Avatar
    May 2010
    Lenexa, KS
    301
    For my car, anyway, MAP is Manifold Absolute Pressure (SAE), not Manifold Air Pressure. And it should log in kPa or psi, not volts
    Kenne Bell Supercharged 2003 Corvette Z06
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    definitely a sensor/wiring problem there. I'd lean more towards sensor based on the data available but I'd checkout the wiring before I spent the coin.
    Steve Williams
    TunedbyFrost.com
    Jul 2010
    Milford, CT
    29
    umrj-I logged both air pressure and absolute pressure because I wasn't sure which to use. It's the Kpa that isn't changing.
    Frost- I have to run a new vacuum line for my heater controls, so while i'm in there I check the wires. How do the rest of my numbers look? The car is running smooth and strong!
