Results 21 to 40 of 47
Thread: Just swapped Injectors, now lean AFR
    Advanced Tuner 69lt1bird's Avatar
    Oct 2007
    983
    Another good reason for getting the re-sized GM injectors from FIC.
    Free HP Tuners Beginners Tuning Guide
    LS1 Tuning Guide
    Michigan Snowmobiler
    1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
    Tuner CLRD4TO's Avatar
    Apr 2010
    Twin Cities, MN
    61
    I called FIC today about my situation and they said to just tune the IFR table to match the previous injector behavior. I did continue the slope on the short pulse adder table. Going to flash and go drive soon.
    I did three logs last night and the changes to the VE are shaping it more like a half pipe than a smooth hill. That definately cant be right. Im starting back to the VE tune prior to these injectors.
    99 Hugger Camaro LS1 M6 TSP Torquer V2 cam, 100 dry-shot N2O, 42# "green tops", lid, p&p MAF/TB, LS6 Intake, Hooker LT's, Custom ORY with Flowmaster Merge, DMH cutout, Magnaflow CB, tuned with LC-1 and '02 OS.
    Apr 2010
    Twin Cities, MN
    61
    Did some more tuning last night. I created a histogram with the IFR table vs AFR err. Problem is now the table populates (from 0) around -5% to as high as 7% (around 40) and back to -5% rich (at 75). The paste X % half function turns the slope into a roller coaster. Id smooth it and log, did this a few times last night. I must be chasing another problem. Im guessing the high/low AFR errors in the VE table are skewing my IFR table. I think Im going to try to tune the VE and IFR by themsleves to less than +/-4%. Hopefully I can get "middle of the road" results.
    Feb 2008
    665
    Just curious did you purchase these injectors new or used?
    2017 Silverado LTZ
    Apr 2010
    Twin Cities, MN
    61
    Used, supposedly 6,000 miles on them.
  6. #26
    Apr 2010
    Twin Cities, MN
    61
    I spent last night tuning again. If I tune just the VE, it turns into a half pipe. If I tune just the IFR, it turns into a roller coaster.
    It also drastically looks like DFCO below 3500 rpms in any cells coasting and engine braking. I have every table in dfco to max speed, 0 map, 0 throttle and it doesnt change anything. Still 20+ AFR in those cells. I flashed back to my original file and letting closed loop and fuel trims fix it until I can drop the car off with my tuner. I surrender.
  7. #27
    Apr 2010
    Twin Cities, MN
    61
    Well I ran into bad luck. My tuner is overwhelmed with work and is declining any new business for the rest of the summer. On top of that, I had a valve spring break. Im lucky to not have any piston to valve contact. Hopefully back at fuel injector troubleshooting next week.
  8. #28
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    Quote Originally Posted by CLRD4TO View Post
    Well I ran into bad luck. My tuner is overwhelmed with work and is declining any new business for the rest of the summer....
    I didn't know we could do that!!
    Steve Williams
    TunedbyFrost.com
  9. #29
    Apr 2010
    Twin Cities, MN
    61
    He does tuning on the side. I dont blame him for wanting to enjoy the summer too.
  10. #30
    Sep 2009
    346
    Im having a hell of a time with the SVO Green Tops as well...
    http://www.hptuners.com/forum/showthread.php?t=30702
  11. #31
    Apr 2010
    Twin Cities, MN
    61
    Whew, Im glad Im not the only one to ever run into this problem. I have a local tuning guru that offered me to look at my tune and help me out. I emailed him and am waiting for a reply back.
    Meanwhile, Ive been getting tired of working on this car so Ive been cutting down the tuning time. Im running Greg's offset, short pulse, and min pulse tables with my previous VE and MAF tables. Ive been tuning only the IFR table. Above 30 kpa, its tuning out very well, less than 3% AFR error. 35 - 80 is still 35% - 40% lean. I keep trimming the IFR cells down and right now its nearly a straight line, no more slope and still lean.
    Last night I copied my current IFR table into my closed loop tune and drove for about an hour. I made another histogram with the IFR vs STFT. (LTFT off)
    -0.3 -5.8 -7.4 -7.9 -9.2 -8.9 -9.2 -8.4 -7.4 -6.8 -4.9 -5.2 -3.7 -5.7 -7.9 -10.0 -6.3
    Its still correcting but not as much as the AFR error is in open loop. I keep thinking there has got to be something outside of the IFR table that is causing this.
  12. #32
    Sep 2009
    346
    Well, your ahead of me and your on the Rich side... I only was rich when in an attempt to see rich, i put my PRE Injector tune in, then i was 20% rich. Now with the tables adjusted I just start the car and at idle and am 38% lean, let alone any other values along the IFR vac.
    I am actually going to go back (rollback to my working tune)and ONLY change the IFR table and go from there, many on LS1tech say they dont adjust the other tables.
    If it still shows large discrepancies, ill more than likely pull the injectors out and sell them as watching the DVD for the 11th is not in order.
    Its odd that many say the xls from Calibrated Success works, and I truly thought it would, but I mean, my car only has a FAST intake and larger throttle which tuned in great prior, I followed the xls and boy oh boy, not even close.
    Injectors themselves or those values are messed, or? what else is a factor, i even thought, maybe i cracked the FAST intake tightening the injectors down.. ill look at that too.
    So I resorted to doing the math myself... and well, its still wrong, just leaving the injectors (they are used)... so I dont know.
  13. #33
    Apr 2010
    Twin Cities, MN
    61
    I know how you feel, Im considering reselling these injectors too. Like Ive stated in my progress above, Ive tuned with stock tables and VE but its still lean with high vac. One more thing I want to do is measure each injector resistance cold and hot. Maybe I do have a bad injector(s) and its just not opening the pintle at low pulsewidths.
  14. #34
    Apr 2006
    western NY
    339
    my green tops with gregs data worked awesome i switched to 60# seimens and entered gregs data and also worked awesome,the short pulse adder for the green tops should look like stairs and make shur your changing your offset vs volts vs kpa table.
    2000 Firebird,2002 O.S.,LQ4 370,Borg Warner S475,truck mani.,Eagle crank,Callies Compstar Rods,Wiseco-11 4.030 pistons 9.4:1 comp.,LS3CNC heads,LS3 intake,NW92mm throttle body,ID1000 injectors,BTR trunion upgrade,LJMS STG3 cam,LS7 Lifters,ARP Studs-bolts,Frozen Boost A to W intercooler,JGS 60MM BOV,2 40mmJGS Wastegates,4L80E trans wth segment swap,CircleD 3400 single disk,MOSER 12 3.31gears ,BMR K-Mem.,2 Walboro 450 pumps,Returnstyle fuelsystem MAGNAFUEL regulator.
    LS1Tech sig KRAZY K 2000 TA
  15. #35
    Apr 2006
    western NY
    339
    i know my fuel pressure is 58 psi to so there is no correction needed for that being off or guessing if that is close.
  16. #36
    Apr 2010
    Twin Cities, MN
    61
    Okay, as stated in a post in smithers thread (link above), I decided to put the stockers back in. Just got in from reflash and short idle log. Back to normal. Nice seeing less than -3% AFR error in the high vac IFR histo. Whenever I have an extra 100 bucks burning a hole in my pocket, I'll send the green tops out for rebuild. Giving up on nitrous again for another season. Oh well, runs great and going to the track on sunday! W00t!
  17. #37
    Apr 2010
    Twin Cities, MN
    61
    Reviving this thread.....
    I sent the injectors out to FIC last month, one was bad, now all cleaned and flowmatched. I also licensed and flashed an '02 OS tune. A couple days ago I put these injectors back in. Low and behold...SAME PROBLEMS!!!!
    These injectors flowed 500cc @ 60psi. I calculated 47.xx @ 0 kPa Vac and 52.xx @ 80 vac, then interpolated to populate the IFR table. Copy/paste GB offset, short, and min tables. Same exact results as last year. Roughly 20% lean AFR in normal driving and max lean AFR on the wideband with engine decel, when scanning with CL and trims off.
    I dont know what the hell to do from here. I've talked with a few local guys that self-tune and they've never heard of this problem either. Attached current tune file. Any input is appreciated.
  18. #38
    Oct 2007
    983
    What is your fuel pressure, it doesn't matter what FIC tested them at.
    LS1 Tuning Guide
  19. #39
    Apr 2010
    Twin Cities, MN
    61
    Stock, 58-60psi
  20. #40
    Apr 2010
    Twin Cities, MN
    61
    Dont know what exactly, but its fixed. I put all the injector tables back to stock except IFR. Somehow I never noticed but the idle LTFT was still enabled. Tuning VE, its within 5% ish right off the bat....should have this tune done fairly soon.
