I'm looking for a few Configs to use for the 2010+ Camaro and C6.
Anyone have any they would like to share?
I'm looking for at least the following:
- Idle Tuning
- MAF LTRIM
- MAF AFR Error (using with WB 02)
Very much appreciated!!!
Bill
- Idle Tuning
- MAF LTRIM
Bill
2001 Camaro SS M6 - 23,xxx Miles
Huron Speed AC Turbo AC Kit - 6.0L 9.4CR, LS3 Heads, 226 232 115 lsa cam, Turbonetics 7575 1.15 AR Turbo
10.98 @ 133 MPH on 9 lbs boost
Gen IV idle tuning is a joke. You really don't need a config file to set it up (at least, I don't use a specific idle config file).
As far as the other things... those are just simple histograms. Log MAF Hz and LTFTs, then make a histogram graphing the LTFT sensor against MAF frequency. Done. Do the same for your wideband, except you'll have to make a wideband error PID.
I do everything Gen IV with the same config file, tailored to the specific vehicle. Just make the histograms that you want. You learn a lot more by creating your own config file than you do just loading somebody else's.
http://www.dsxtuning.com
Just say no to bull s***.
While I agree, I don't have a 2010 Camaro to use at my disposal to set up configs and try out.
If I can get some as a starting point, then I can tweak them as needed when I get a car to tune.
Most of the basic E38 configs should be more than enough to tune.
G-FORCE Motorsports
1941 CR 129 Pearland TX 77581
281-993-5451 PH 281-993-5421 FAX
www.gforce-tx.com
[email protected]
PCM Tuner LSX and SCT <-> How Much Force Can You Take??
2009 CTS-V 630 RWHP 10.90 @ 129mph
