Results 1 to 4 of 4
Thread: 617HP all boost 4.8L..now running 75 dry shot
    Feb 2010
    9
    Hey guys, I was wondering if someone could look at this log and tell me why it's spraying past my 5950rpm cutoff. It seems to keep spraying on and off at 6300.
    Setup:
    Stock 4.8L w/ls6 cam/springs
    MP70 @ 15psi makes 617HP/623TQ
    Dual Walbro, 80LB injectors, E85
    After the dyno tune, I've added a 35, then 50, now 75HP shot. Currently on the .42 pill, 950psi bottle pressure, 15psi boost.
    Current Disable trigger:
    [SENS.90] < 98 OR [PID.12] > 5950 OR [SENS.120] > 12.3
    Also, always read rev limit and nitrous = bad news. Is this true with a dry shot or is that mostly for the wet camp?
    Thanks guys
    Feb 2010
    9
    2004 GMC RST: 4.8L/Turbo/E85: 617HP/623TQ
    http://www.youtube.com/watch?v=V9nRm6vZl_I
    91 Eagle Talon 2.0L/Turbo/E85-10.61@136, 570AWHP Mustang Dyno
    http://www.youtube.com/watch?v=yB9kDxXRLgw
    Feb 2007
    San Antonio, TX
    1,255
    Quote Originally Posted by Foose04 View Post
    Thanks guys
    Statement is 100% accurate. Hit fuel cutoff (rev limit) and nitrous doesn't cut prior you're gonna go lean. Your taking away the fuel in the fuel/oxygen equation at that point. Not good with boost on top of it. Have you considered running a seperate window switch?
    Have you tuned your MAF/VE tables? Your STFT/LTFT are way outa' whack...You're running your injectors at 99%+ duty cycle. They need to be replaced (upgraded!).
    Janky Monkey Tuning
    Call or PM for tuning solutions.
    Cell 210-954-4985
    Wrench turning provided by 2 Tightwads Racing.
    Tune your own? Start here ----> Open Editor ---> Hit F1...READ!
    READ SOME MORE (Thank username 69Lt1bird): http://ls1tuningguide.com/
    Still lost? Consult a Pro!
    www.thetuningschool.com
    www.calibratedsuccess.com
    www.tunedbyfrost.com
    Feb 2006
    South Carolina
    1,525
    It may just be a lag in the display response. Your output may be responding on time but the "log" is behind slightly.
    If you drag the maker from the left to right it shows it on until 6300, but if you then drag it back from right to left it stays off at RPM=6184. Still an overshoot, but I'm not sure I completely trust what I'm seeing. I would try to find another way to verify the display.
    Also, I would definately take the rev limiter way out of range running a dry until you get a reliable window worked out.
    EDIT: After a little reading, your output disable relies on that statement to be true for at least 1 frame before it switches. You may need to adjust your statement quals to get the desired switchpoint.
    Jaime
