Results 1 to 10 of 10
Thread: B1S1 off the charts
    Jul 2010
    Milford, CT
    29
    B1S1 off the charts
    I'm just getting started with tuning, but I'm having an issue that's keeping me from getting the basics done. For some reason my B1 O2 isn't oscillating, and it's reading off the charts. I swapped in a new with the same results. The car runs great till it goes closed loop, then bank 1 goes way rich. Any advice on what to check would be greatly appreciated.
    Car has LS6 Stage 2.5 heads, MS3 cam, Long Tubes w/cats, LS6 intake.
    Advanced Tuner 69lt1bird's Avatar
    Oct 2007
    983
    Have you thoroughly checked the wiring to the O2 sensor, melted, cut, etc.
    Free HP Tuners Beginners Tuning Guide
    LS1 Tuning Guide
    Michigan Snowmobiler
    1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
    Jul 2010
    Milford, CT
    29
    Yeah, I just put a meter on it. I'm getting power to black as well as the white heater feeds.
    Oct 2007
    983
    Go here and recheck you pinuts.
    http://chevythunder.com/ls1_page_1.htm
    LS1 Tuning Guide
    Potential Tuner pajeff02's Avatar
    Jun 2010
    Mansfield, PA
    9
    Greetings, Mr. Kid. Subscribed to see how you make out on this.
    Tuner edgZ06's Avatar
    Mar 2005
    Pro Edge Tuning, CT.
    77
    Looks like you have a cylinder down. Or a really bad exhaust (upstream of 02) or vacuum leak.
    Could be
    Injector not plugged in, bad injector, unplugged or bad coilpack, unplugged spark plug wire, cracked sparkplug, etc.,
    Check all connections at injectors, coilpacks and spark plug wires. If there is nothing obvious, with the car running unplug one injector at a time, when you don't hear a change, you've found the right cylinder.
    No change, do the same with the coilpack plugs.
    No change, do the same with the sparkplug wires.
    No change, Swap banks for the coilpacks, plugs, wires and injectors.
    Remember, no combustion in one cylinder will show a lean bank 02 and fuel trims will be +.
    Process of elimination will find the problem. Did you just put the car back together?
    2004 GTO A4
    UNDER CONSTRUCTION....
    Previous E.T. 10.66 @ 130 mph
    http://www.mongillomotors.com/1066vid.html
    2008 G8
    LS3 76mm Turbo. 582rwhp
    2003 S600 Mercedes
    V12 Twin Turbo 21psi 600 rwhp
    2007 Factor Five GTM
    Twin Turbo forged LS6 600rwhp
    2015 Polaris Slingshot
    Tune & DR
    www.ProEdgeTuning.com
    Tuning with HPTuners & Mustang MD-1100 Chassis Dyno
    Wallingford, CT.
    [email protected]
    Jul 2010
    Milford, CT
    29
    Yes, I did a total tear down of the drivetrain that started about 8 months ago. I have no leaks upstream that I can hear. I've welded most of the exhaust. I have a slight leak AFTER the O2 in the cats (didn't want to weld the cat in) but that shouldn't mess with fuel trims, right?
    I'll run through the steps today you outlined when I get home. I was throwing a misfire code every so often, but I was contributing that to a rough idle to stall. Thanks for the advice edg. Hopefully be seeing you guys soon!
    Jeff- I'm curious to see how I make out as well...lol.
    Jul 2010
    Milford, CT
    29
    Well get that man a cigar! Edg wins the O2 mystery game. I started by pulling plug wires, no change withany of them. I forgot how hard that was to judge on a V8. Started pulling injector wires, no change either, till I got to the third one. The engine started to surge. I noticed it was when I touched the main coil pack input. I pulled off the tape and was greeted with the attached picture of splices. The dark green was not making a connection, so I respliced, and she smoothed right out. I pulled a scan, and I'm now getting proper function from both the O2's. And as a bonus, my STFT's aren't bad considering all I did was reslope the injectors. I'm hovering around 2-3. fairly consistently. Easy fix! Thanks for all the help on this!
    Oct 2007
    983
    That needs solder and shrink tube bad.
    LS1 Tuning Guide
    Jul 2010
    Milford, CT
    29
    Yeah, I did a twist and tape just to check it was the only issue. I'll cut, solder, and shrink all of them tomorrow.
