Results 21 to 40 of 43
Thread: Fastest LSX with your software?
  1. #21
    Dec 2005
    Sydney Australia
    510
    went 8.2@169 last night.. ignition and 8 ID2000's controlled by the factory LS1 pcm running the HPT 3bar os...
    http://www.youtube.com/watch?v=hPsYYPyP0so
  2. #22
    Dec 2007
    776
    Quote Originally Posted by VYSSLS1 View Post
    Got outta the hole nice on the last run !
  3. #23
    Dec 2005
    Sydney Australia
    510
    it was actually slower than the first too.. only a 1.25.. the 2 step just upsets the car too much.. converter is going back to get loosened up a little this week.
    i just need a set of the tall corvette rocker covers to fix a little oil leak...
  4. #24
    Dec 2007
    776
    mmmm....... optical illusion then. It looked harder. Was that a 9.06 on the last run. Vid was only on the readout for a moment.
    Better air after the sun went down?
  5. #25
    Dec 2005
    Sydney Australia
    510
    the last run was a 8.2@169
    the first 2 we were just getting some data as we cant hold it down on the dyno so the tune is a lot different at the track so we only ran it through to half track..
    next time out ill start on winding up the boost and it should run a 7.70 or so..
  6. #26
    Apr 2009
    2
    Been 9.d0h a couple times @ 152 in a 4300lbs TBSS using HPtuners...
    http://www.youtube.com/watch?v=eGaUyTnAnOw
  7. #27
    Dec 2008
    on the Dyno
    1,825
    Well I guess the fastest that I've personally tuned is my own car... 9.64@143 403" 6speed full weight car on a 150 shot.
    Located in Central Kentucky
    ShorTuning
  8. #28
    Dec 2005
    Sydney Australia
    510
    we went out yesterday with another 500hp on board but the box couldnt take it and for some reason lost 1st gear...
    very dissapointing not to run a 7 this year but theres always next year
  9. #29
    Dec 2006
    Fort Lauderdale
    171
    Our twin turbo 04 Z06 is running an HPT 3 bar OS with 96lb injectors at about 20psi making roughly 1000rwhp.
  10. #30
    Dec 2008
    on the Dyno
    1,825
    What is the limiting factor on the stock PCM. I've been told that the coils can't keep up past around 12-1300hp. I'm currently building a sleeved stroker with a Thumper and it'll probably see 20-25psi of boost and I'm shooting for around 1500whp with it but trying to see what you guy's making that power have run into.
    ShorTuning
  11. #31
    Tuner Doubledip's Avatar
    Apr 2007
    Sydney, Australia
    161
    VYSSLS1's Drag car must be pushing round the 1400-1500hp mark and has shown no sign of the factory coils not keeping up... only downfall i have heard of with the factory LS1 PCM is it cant have the RPM limit raised above8000rpm
    Ultimate Conversion Wiring
  12. #32
    Dec 2008
    on the Dyno
    1,825
    Well that doesn't bother me cause this is going to be a hydraulic setup with a maximum of around 7500. Also I'm not sure on the 8K limit either cause there have been a few guy's crank around 9K rpm with stock PCM NA they just had to fudge the 8K rpm column on fuel and timing. Due to it being the end of the table from my understanding it just keeps reading the last value on the table. I could be wrong about that but havent had a setup that was capable safely going past 8000rpm. I guess I'll just push forward with the 3bar OS and see what happens.
    ShorTuning
  13. #33
    Feb 2007
    San Antonio, TX
    1,255
    Quote Originally Posted by jakebdb56 View Post
    I can't remember if Flaco is running the stock ECM or not with his setups, if so he's in the 8.8's with the 414 white turbo truck.
    I'd love to get the S10 into the 9's, but a 8 is crazy fast
    BS3
    Janky Monkey Tuning
    Call or PM for tuning solutions.
    Cell 210-954-4985
    Wrench turning provided by 2 Tightwads Racing.
    Tune your own? Start here ----> Open Editor ---> Hit F1...READ!
    READ SOME MORE (Thank username 69Lt1bird): http://ls1tuningguide.com/
    Still lost? Consult a Pro!
    www.thetuningschool.com
    www.calibratedsuccess.com
    www.tunedbyfrost.com
  14. #34
    Advanced Tuner jakebdb56's Avatar
    Oct 2006
    Houston, TX
    646
    Quote Originally Posted by Cantalope Kid View Post
    BS3
    yeah saw that recently in a pic a friend had posted of the interior
    '20 AT4
    '01 Suburban 2500 Dad Wagon
  15. #35
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    Quote Originally Posted by DBTBSS View Post
    Pretty sick run with a heavy SUV
  16. #36
    Dec 2005
    Sydney Australia
    510
    thats what i was running in my car..
    but just got too tricky to run a seperate computer for another 8 injectors on the methenol so we swapped to a Haltech PS2000 with a IQ3 logger etc..
  17. #37
    Dec 2008
    on the Dyno
    1,825
    I know this is quite old but is the Haltech PS2000 a prototype EMS? Or is it not sequential coils and injectors? The Haltech USA rep said there was a new EMS in developement with multiple programmable sequential channels but didn't say when they would be out.
    ShorTuning
  18. #38
    Apr 2007
    Sydney, Australia
    161
    A Haltech PS2000 is a haltech platinum sports 2000 ECU... a EMS is a EMS (Engine Munching System).. 2 totally different brands...
    the 2000 can run sequential injection and if teamed up with a CDI can do multi coils sequential as well (digitally) - well pretty sure
  19. #39
    Dec 2007
    776
    Quote Originally Posted by Doubledip View Post
    ROFL
  20. #40
    Dec 2008
    on the Dyno
    1,825
    LOL
    Good info, I'm mainly looking for something to keep factory coils. Now don't the Platinum's only have 12-14 sequential drivers?
    ShorTuning
