Page 1 of 3 123 LastLast
Results 1 to 20 of 48
Thread: Russ k's adaptive idle config.
    Mar 2010
    Hartford Ct.
    12
    I am having problems with my truck hunting for idle at hot/cold start up. While searching for a solution to fix this, i see where some people were using this config. to help get the idle straightened out. I have searched for his config., but i cant find it. Thanks in advance..........Bob
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Here is my idle .cfg file.
    Russ Kemp
    Mar 2010
    Hartford Ct.
    12
    Thanks alot for sharing
    Jun 2007
    396
    Russ, is there also a write up on how exactly to use your config? This cfg is used for tuning the cracker and follower values, correct?
    Can it also be used for full RAF tuning once VE and MAF are tuned properly?
    2011 Z07 Carbon Edition
    Mar 2010
    Hartford Ct.
    12
    Quote Originally Posted by Eagle View Post
    X2
    Dec 2005
    Regina, Sask.
    4,214
    Cold engine key on, start scanning, then start engine & let idle till operating temp without touching the throttle. Then copy the #1 idle desired airflow histogram (average) and paste into the RAF table of the editor. Make sure that the same units (imp. or metric) are used in both the scanner & editor.
    Repeat in gear if A4 trans.
    Russ Kemp
    What kind of idle issues will this resolve?? I played around with my OLFA table to lean my idle out. If I use this, should I go back to my stock OLFA?
    MY car started to stumble a lot at idle, will this help with that?
    Mar 2010
    Hartford Ct.
    12
    Thanks Russ. Its nice of you to help out the way that you do...........
    I will be running the congfig. later on tonight.
    Jun 2010
    wethersfield, ct
    69
    will this work for ls2 gto's?
    when i connect with the scanner it say the parameters are unsupported.
    Oct 2009
    42
    Quote Originally Posted by streetsweepergto View Post
    no the ls2 is totally different.
    Oct 2009
    42
    try this
    Sep 2010
    Ridgefield, WA
    4
    Quote Originally Posted by Russ K View Post
    Russ Kemp
    Hey Russ,
    Do you know if this procedure would work for Vortec idle tuning? I am working with a 99 Astro van with a 99 Suburban 350 tune and a HT383E replacement.
    Jason
    1996 Cadillac Fleetwood
    Will doing this work on my 2003 Grand Prix GTP also?
    2003 Galaxy Silver Limited Edition GTP
    Mods: 2.8 MPS | S2IC | XP CAM | GEN V | 65# | E85 | TOGS | N* TB | HPT PRO | Impala Brakes | BUILT TRANS w/3.29 GRS
    2017 Chevrolet Silverado LTZ 6.2
    Mods: HPT PRO
    May 2008
    Wichita, Kansas
    147
    Quote Originally Posted by erics_02_z06 View Post
    I think that this would only resolve your issue in open loop correct? Once in closed loop it would do its own thing since its using the O2s but I dont know for sure, someone help me on this cause I just switched to E85 and am having some minor idel issues (hunting after pushing the clutch in). Dont mean to hijack your thread.
    2015 Yukon SLT 5.3
    Dec 2010
    13
    My Histogram is Blank.
    I am sure it is something I am doing, since I am new to this thing. I followed the instructions, and after I ran the engine with the scanner in the scan mode, the Histogram was blank on all pages. I may be looking in the wrong place for the histogram, or I might not know how to tell it to start logging.
    Any help would be much appreciated.
    Dave
    Tuner Chevy406's Avatar
    Nov 2007
    Huntsville, AL
    163
    After you open the histogram window:
    Did you try a right mouse click and then click on "load all values" in the pop-up window?
    May 2010
    39
    Quote Originally Posted by nitetrain44 View Post
    Dave
    Quote Originally Posted by Chevy406 View Post
    I just tried this also... the config file he has posted is all blank. And the right mouse click has no option of "load all values".
    Mar 2011
    27
    Am I missing something here? I copied my value from the histogram, but the Running Airflow table doesn't change when I paste the value.
    May 2010
    39
    good luck getting an answer... this forum sucks.
    Mar 2011
    27
    Quote Originally Posted by Pwrtrip75 View Post
    I found it's better to PM then to post something up
