Results 1 to 14 of 14
Thread: GM LS3/LS7 card style MAF WOT run
    Advanced Tuner 69lt1bird's Avatar
    Oct 2007
    983
    Here is a screen shot of how the card style MAF works in out for our Gen III setups. I do have a screen in my tube about 6 inches in front of the MAF.
    I have a Amsoil oil-less air filter to a 4" OD (96 mm ID) tube to the MAF section, connected by silicone couplers, then more tube to a 90* elbow to a 90 mm Holley TB. Pretty much no restriction to speak of, about a 2 kPa drop.
    This is a good pass, I had the timing detuned by accident and also some timing being pulled from a prior tune I was using after I replaced the trans, oops, lost a bunch of timing, I usually run 30* in this thing. 11.7 @ 114 with a DA of 2500.
    It shows how smooth the MAF Hz can read, it used to bounce a lot, very jagged, before the screen.
    Free HP Tuners Beginners Tuning Guide
    LS1 Tuning Guide
    Michigan Snowmobiler
    1969 Firebird: 11.67@114 [email protected] 1/8 1.70 60 ft. EPS cam 234/246 .602.606 114+3, 6.0 LQ4, L92 heads milled 10.5:1, Ported L76 intake, ported 90mm Holley TB, 100mm MAF, FIC Custom injectors, Hooker LT, PYPES dual exhaust with an X pipe, 4L65e with all of the good parts inside, FTI 4000 RPM Stall, 12 bolt with 3.73 gears. HP Tuner tuned by me
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    nice, that does look really smooth!
    Steve Williams
    TunedbyFrost.com
    Ive been tossing the same idea around for a while. I have the MAF and a Halltech housing just sitting around.
    Are the pins the same on the older MAF and the new card style? Or do you have to swap some wires? I had to swap them around when I was tinkering with the Lingenfelter 100mm MAF.
    Oct 2007
    983
    You need to swap a couple, not a big deal.
    I used this as a guide. My harness is from a 2002 truck.
    LS1 Tuning Guide
    Quote Originally Posted by 69lt1bird View Post
    How did yo install this, and what did you use for screen?
    Oct 2007
    983
    GM makes a small aluminum boss you can screw or weld to your tube and the card style MAF slides through and screws into. I can't find the pic and part number. It comes in their LS3 stand-alone harness and PCM kit. A dealer should be able to find the PN.
    The screen is from http://saxonpc.com/.
    LS1 Tuning Guide
    Ive got the info on the weld on piece, I was wondering how you attached the screen, and your link does work either
    Oct 2007
    983
    Their site must be down.
    I put a film of two part epoxy on the outside of the screen and then slid it into my aluminum tube. It can't move. The screen is about 1/2 in. thick.
    LS1 Tuning Guide
    I just picked the screen up. I'll let ya know how it goes. :-) Now I need to find a medium viscosity epoxy.
    Aug 2009
    Calibrating
    3,373
    Is the screen made of aluminum? I am wondering if I will need one (will find out soon). If its a tight fit I figure it could just slide in and stay.
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
    I glued it in with JB Weld and haven't looked back. I'd be very hesitant to let it just sit in there. It did make the MAF more stable especially at low load/rpm.
    94 BB Rx-7 02 LS1
    Tuner Ricardo's Avatar
    Jul 2011
    5000 ft ASL
    79
    I am doing a custom CAI for my LS7 and want to add a card style 100 MM maf to it.
    Just ordered a couple of straighteners.
    Thanks for the link
    Ricardo
    1996 A4 FBody with LS7 swap
    What are the recommended changes to perform in the tune when running one of these? What are the improvements to be expected over a factory modular MAF?
    2001 Z06 - 417 LS3 - LPE CNC LS3 heads - LPE GT-11 cam - ARH 1 7/8" - LPE C6 intake - RPM 3.73 diff - tuned with HP Tuners
    2008 Silverado 5.3 - Dynatech LT headers - Volant Cool Air intake - 280whp/303wtq - tuned with HP Tuners
    www.davenportmotorsports.com
    Jul 2011
    5000 ft ASL
    79
    Quote Originally Posted by Sherminator View Post
    You will have to recalibrate your MAF by modifying the table (airflow vrs freq.)
    Bigger inlet duct diameter= less restriction at wot = more air into an engine
    I am actually fighting a 5kpa pressure drop at WOT.
    You can also flow and measure greater amounts of air.
    Ricardo
