Got a few logs from lastnight, see what you guys think..
motor is an LQ4 with 92/92, X1 cam, MTI 2E heads.
trans is TH350..
The car had a LS1 with the same head/cam, #7 let go, so I put it back together with an iron block, and new intake to flow her out alittle better..
I am just trying to dial in, using my old tune, and make the changes for the intake and new injectors.(green Svo)
These are both while I am trying to trim out my LTFTs.. I just want some advice before, I start with the STFTs, and if there is anything I have missed..
I am pretty new to this, and I have been lurking, and using the write ups... so please understand I am no tuning Wiz
Also if you need any other info, please just let me know.
ignore the WB02 signal, it wasnt hooked up, found it wasnt working correctly
