Results 1 to 8 of 8
Thread: 2 Bar OS Questions
    2 Bar OS Questions
    I have a few questions about the 2 bar OS for the E38 pcm.
    Can I still run the car in Hybrid mode, ie SD up to 4k and Maf after that?
    Can I run a stock Map with the OS? Car is a 2006 Z06, the help file says it is possible just wanted to see if anyone has done it.
    Can I go back to the stock OS just by reflashing my old tune with a write entire?
    Thanks in advance for any help.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,247
    You can run the stock map but it won't read up to 2 bar so you'll need to scale it accordingly.
    And yes you can always switch back to the stock operating system at any time.
    Thanks Bill.
    Do you know if I can still run in Hybrid mode? and if I can would that mean I dont need to apply the TCS patches?
    HP Tuners Support
    (foff667)
    28,247
    Yes you can run the maf
    Thanks Bill.
    Map PID?
    I can not find a non SAE Map with the 2 bar OS I just installed. The readings look the same as they did with the stock OS, just want to make sure before I tune with it. I remeber reading a post by Bill that you had to delete the SAE one and use a 2 bar one. Is that only for some PCM's? This is a 2006 Z06 with the 2 bar OS, but a stock MAP at this point.(I need the VE table more than the extra boost range)
    HP Tuners Support
    (foff667)
    28,247
    It uses the sae pid, considering you can run a 1 bar map, 1.3bar map, 2 bar map, 2.5 bar map or 3 bar map in these applications creating all those pid's would've been pointless
    Thank you again and again Bill....You are Awesome.
