Is there a reset for the IGN trims to revert back to the high octane map. I've made quite a few passes now with no knock, and it's still prefering the low octane map.
are u in speed density mode
No, just MAF
Log the knock learn pid, it should give you an idea of whats going on.
That doesn't seem to be an option, nor Total KR, only Retard(deg), and actual timing. I'm using your config file, and both those don't have a number next to them. Retard has a 0 next to it untill it starts to see knock.
You need to insert the knock learn pid into the table display, you should have no problem adding it if the knock retard pid logs fine.
Knock Learn =.02
This is similar to yours, http://www.hptuners.com/forum/showth...ht=knock+learn has some helpful info in it.
