Results 1 to 14 of 14
Thread: AEM Wideband
    AEM Wideband
    Any solution yet for getting an AEM Wideband to work with HP Tuners yet?
    HAI, 180* T-stat, Autolite 104's, NorthStar, Gen V, 1.8 SLP Rockers, SLP Ported Headers, Custom 3" Downpipe w/high flo cat, Dynomax Catback Exhaust, DHP PCM, Fuzzy Dice Mod.
    They don't work ?
    Whats the problem ?
    Advanced Tuner TXZ0603's Avatar
    Dec 2007
    Houston, Tx
    375
    Been using mine with it for years
    2003 Z06
    Forged 347
    PTE Billet 67/65 Turbos
    FMIC / Dual 50mm Tial BOV's
    ID 1000 Injectors
    RSI Stage 4 Fuel System
    07 Z06 Cam
    Tripple Nozzle Meth
    ACT Twin disk clutch
    25# Boost
    Mar 2009
    44
    AEM works GREAT with HPT. It should already be setup for you to use. Just add the pid.
    From what Im understanding, it wont work in beta for standalone logging. works real time scanning tho. Mine does, I have the exact same gauge.
    Mar 2009
    44
    I haven't tried standalone logging with mine in beta, so maybe that's it.
    May 2006
    Upstate NY
    207
    Standalone EIO was disabled in the latest beta as they are working out some issues.
    GM World Class Technician
    ASE Master Auto Technician
    L1 Certification
    2001 Silverado 6.0L Swap
    Using the standard PID, it just reads 12.5 on the scan list and on the chart it also says 12.5 and stays there. My commanded AFR does the same in the charts but changes on the list to read down to 10.3 at WOT. The commanded AFR seems to match the same as the wideband but I can never get it to log properly. Is it possible I have it hooked up wrong to the Tuner? Red wire to #1 input.
    Advanced Tuner umrjmac's Avatar
    May 2010
    Lenexa, KS
    301
    Did you connect the ground wire to the 5th spot on the EIO plug?
    The pre-defined transfer function for the AEM is volts / .5 + 10, which would mean that the MPVI is reading a constant 1.25V
    Try watching the voltage using a DMM to see if it changes or stays constant.
    Kenne Bell Supercharged 2003 Corvette Z06
    Ground wire was the problem. One of my buddies had the same issue and he didn't know about the ground wire either. Fixed his on my break and just got mine to work.
    Thanks for the answer!
    Tuner in Training Driver's Avatar
    Jan 2011
    18
    So can you log in beta?
    Tuner wreckwriter's Avatar
    Apr 2009
    West Virginia
    147
    No wideband can do stand-alone logging in beta now, its disabled. I asked Bill about it a week ago and he said hopefully within a couple weeks it would be re-enabled. you can log wideband with laptop, not without.
    2008 Pontiac G8 GT, IHRA Modified, NHRA Pro ET
    Apr 2009
    West Virginia
    147
    Bill, any luck with getting standalone WB logging re-enabled?
    Sep 2008
    9
    I am having the same issue as 04 Intimidator was having without the ground fixing it. I checked my voltage with a DMM and it is changing voltage @ my white wire from a little over a volt to almost 5 volts but still only reads 12.6x-12.8x until I played with my config and got it to read 15.6x constant without change of more than .10 also attaching my modified config i'm using. I have also tried it with and without a ground wire attached to slot 5 along with the white wire in slot 1,2,3, or 4 with the same issue no matter how I have it wired. Any help or info would be greatly appreciated.
