This is on my '03 Z06 with the 2bar tune and .5bar boost. I have been getting drastic shifts in my afr under boost (between cells that had similar settings in the fuel cells) that didnt make sense. So I decided to start logging commanded afr to see what it was actually commanding. Turns out it has been commanding 13.93 and some other lean values even though it should be commanding 11.76 all throughout the boosted regions above 120 kpa. It seems to me that it is bouncing back and forth between the PE and the BE table but it should be using the richer of the two which is the BE table. Normally I have my LTFTs disabled but I turned them back on to help out with fuel mileage and it does show LTFTs when it is under BE. I know Im getting a bunch of KR too but Im assuming that its related to the less than subtle afr shifts and some lean conditions. I would appreciate any thoughts.
