Results 21 to 40 of 43
Thread: LNF - Logging Boost pressure above 22 psi w/ 3 BR MAP's
    Senior Tuner Iam Broke's Avatar
    Jul 2009
    2,305
    Same log from Friday as above with the 2 PID's in the same group. Not too shabby. Mani PSI will show vac/boost, Charge PSI only shows the lower CP pressure.
    '12 Camaro T3 2SS/RS LS3 M6, SLP TVS 2300, Flex Fuel
    Mar 2009
    676
    Keeping an eye on this. My Sensors will be in tomorrow, and I wanna put them in ASAP.
    Feb 2010
    The Desert
    480
    Quote Originally Posted by Iam Broke View Post
    Drop your DAL's a bit in the midrange. I'm around 270 for 24 psi, spikes 25 for a split second than cuts back. Also tapers to 18 psi @6k.
    The more you exceed 24psi, the greater the risk of ring land damage on long hard pulls.
    Tried dropping my DALs quite a bit (260s) and I still spiked to 26lbs this morning... Going to put the DAL back to stock with some slight tweaks past 4500 (4490) RPM.
    Wondering if I should back down on the Max air load table as well?
    Advanced Tuner Gimpster's Avatar
    Sep 2009
    Palm Bay, FL / Austin, TX
    445
    Heh, nice to see my hours work in Excel was good for something!
    Jul 2009
    2,305
    We appreciate it!
  6. #26
    Feb 2010
    The Desert
    480
    Quote Originally Posted by Gimpster View Post
    Really appreciate it Gimp!
  7. #27
    Advanced Tuner GeoffH's Avatar
    Jul 2009
    Panama City, Florida
    344
    Quote Originally Posted by T-Man View Post
    Thats what i did! ran the stock GM tune DAL and went up about 10% or so in the higher RPM's, but it still spikes to 27-29psi on a heavy load. and the MALT table is at 100% on most of the table.
    Here is a short video of my boost gauge
    http://www.youtube.com/watch?v=K04ABDIW_vQ
    2008 HHR SS 5-speed
    HP-Tuned
  8. #28
    Tuner kuprito's Avatar
    Nov 2008
    Spain
    137
    I've got 315-320 on the high rpm/load range. I am seeing 30psi peak and 23.2 at redline (7000rpm).
    Should I down my DALs?
    Only motor
  9. #29
    Jul 2009
    344
    Are you getting any knock? And could you post up a log of a run?
    2008 HHR SS 5-speed
    HP-Tuned
  10. #30
    Nov 2008
    Spain
    137
    Quote Originally Posted by GeoffH View Post
    There is some knock but I had it before too (almost stock tables), I think it's due to the MAF which is located on a 2.5" pipe, I've recalibrated too many times and it seems it is not too accurate to make the 2.5" pipe readings as accurate as in the 3" pipe. I am waiting for a 3" pipe and keep things in order.
    Only motor
  11. #31
    Jul 2009
    Winfield/Ofallon MO
    600
    I would be afraid to push 30psi for very long on the stock turbo. I don't think the piston ringlands like much over 25 either.
  12. #32
    Nov 2008
    Spain
    137
    Is possible to have 25psi (no peaks) between 3500 and 7000rpm?
    I'd love it (and my clutch too).
    Only motor
  13. #33
    Jul 2009
    344
    have another log of a pull and driving around while going WOT and not just at idle?
    2008 HHR SS 5-speed
    HP-Tuned
  14. #34
    Jul 2009
    2,305
    270 kPa is around 24 psi. I'd work from there to save the piston ring lands & turbo.
  15. #35
    Nov 2008
    Spain
    137
    Sorry for that!
    I am trying to upload the right file but there are problems with the server...
    Only motor
  16. #36
    Jun 2010
    8
    I'm not seeing PID.2339...yes I'm new to this. I've tried a couple things to get a boost reading in psi, but no luck so far.
  17. #37
    Jul 2009
    2,305
    Perhaps scroll down the list farther, IIRC, they are not in order. Been a while since I looked though.
  18. #38
    Jun 2010
    8
    Yeah, I noticed that, but I still don't see it. It appears to be working though. I'll have to get a new log to make sure.
  19. #39
    Aug 2007
    503
    Is it me or is the tmap sensor reading more boost during part throttle than the map on the intake manifold? At full throttle they're both dead on.
  20. #40
    Jul 2009
    2,305
    It's possible, the throttle plate is in between the two sensors so the turbo can be generating more pressure in the lower CP than the throttle plate is letting into the intake manifold. I never paid attention to that.
