Page 1 of 3 123 LastLast
Results 1 to 20 of 43
Thread: LNF - Logging Boost pressure above 22 psi w/ 3 BR MAP's
    Senior Tuner Iam Broke's Avatar
    Jul 2009
    2,305
    We've been fooling around in another thread, but I wanted to start a new one so it doesn't get lost.
    You can create a custom user defined PID for logging the boost pressure above 255 kPa or approx. 22.4 psi.
    After much calculation & trial and error, the LNF 3 BAP GMPP sensors can be logged for boost pressure above 22.3 psi.
    You will not see manifold vacuum or pressure with this, but the lower CP pressure from the 3 bar TMAP seems pretty accurate, at least on mine.
    Posted in another thread...
    Logged it on the way home and did a pull, peaked at 25.4 and as it tapered down the boost at WOT, I saw 22.3 psi @ 254 kPa on the MAP. Looks pretty damn close on mine up top anyway. Still seeing .8 boost with the key on, not running. Pressure depends upon load and rpm while cruising, but that makes sense to me as the turbo spools there will be more pressure in the pipe before the throttle plate.
    I'm going to look through the PID's for the 3 bar MAP voltage if it exists, then we will see mani pressure/vac. Edit: None found
    To repeat... for the 3 Bar MAPs, the formula
    ([PID.2339]*9.369)-([PID.2340]/6.895)
    (Boost sensor V * 9.369) - (BARO sensor / 6.895)
    looks good but only reads positive boost pressure in the lower CP.
    EDIT: I had to subtract 0.8 psi from the entire product of the above formula to get my readings to match at 22 psi, might be sensor differences.
    If I'm way off base, someone please straighten me out. We couldn't have gotten this close without Gimpsters MAP Voltage tables. Thanks Andy!
    Hopefully BYT will repost his 2.5 bar findings.
    Aug 2007
    503
    Quote Originally Posted by Iam Broke View Post
    Im seeing around .5psi with the key on, though i subtracted pid.51.psi rather than [PID.2340]/6.895. Plus im getting the raw voltage from the map sensor on the intake manifold and not from the one on the ic pipe.
    I'll do some logging tomorrow as its raining now and see how it differs from the regular map pid using your formula.
    Jul 2009
    2,305
    Your sensor will also show mani vac in PSI. 1 PSI ~ 2"/hg. I don't have the pro HPT or I'd be using that one also. Sensor accuracy is crap at the low end, I suspect that's where the positive zero is coming from. No PID for MAP voltage in my version of the scanner.
    The trouble with using the lower CP sensor is it only matches manifold pressure at WOT.
    Aug 2007
    503
    At idle it hovers around -9psi, i don't have a map voltage pid either, i meant comparing it to the map pid that's limited to 255kpa.
    Jul 2009
    2,305
    -9 psi is very close to 18-19 " hg vacuum. It's 2.036 " Hg per PSI.
    I think you got it!
    I saw around that at idle on my old boost pid I had built that capped at 22.3 psi from the MAP sensor.
    Aug 2007
    503
    Alright here's that log, Boost2 is the map pid - baro, Boost3 is the gmpp 3bar voltage reading using your formula. Is yours as erratic too? Maybe i should add a ground to the eio. The regular boost pid was simply map - 14.5, not as accurate without a real baro reading.
    Seems pretty much dead on.
    Jul 2009
    2,305
    I'll have to look tonight. I don't think it was that erratic. I didn't do a pull this morning, maybe tonight.
    Jul 2009
    2,305
    Boost spiked to 27.1 @ 4100 rpm, I guess I need to back the DAL's down a bit. Gauge wrapped to ~26 out of the corner of my eye. Seems pretty close.
    Jul 2009
    2,305
    It read 22.1 psi at 249 kPa on the way down but it is a bit erratic on mine also. I think it lacks resolution.
    Aug 2007
    503
    Why, whats wrong with 27psi?
    I added a ground to the eio just now, we'll see if it makes a difference tomorrow but i guess if its erratic for you too then i doubt it. But yours is a bit smoother off boost, maybe the ecm is smoothing it a bit.
    Jul 2009
    2,305
    Didn't know I was boosting that high before, that explains the burst of KR I see when IATemps are up. Redid the DAL's to 270 kPa (24.x psi I hope) until the pressure starts to decay, then ramped them up a bit more to try and compensate. Need WG duty cycle control.
    Feb 2010
    The Desert
    480
    I've tried inputting this formula and unfortunately, it will not work for me? Something I'm doing wrong maybe? Are we to stick to the PID only and not use any sensors?
    Aug 2007
    503
    Do you have the 2339 pid in your list? My older version of the scanner didn't, looks like you need a recent beta.
    Jul 2009
    2,305
    Quote Originally Posted by T-Man View Post
    Make sure you have the pid's 2339 & 2340 (Boost sensor V & BARO sensor) in your table list first or it will not work. They have to be in the table for the formula to work as a custom PID.
    Feb 2010
    The Desert
    480
    Quote Originally Posted by shabby View Post
    Yes sir, most recent up to date Beta.Yep have the PID in my list.
    I have both in the table as of now. Wish me luck
    Thanks gents.
    Feb 2010
    The Desert
    480
    Spiking to 25lbs in the mid range...
    I love boost but damn does this scare me! Haha.. 91 octane piss water and stock GMPP timing, hand smoothed. Anyone see a problem with pushing this kind of boost in the mid range for long term durability? Boost tapers down to about 17-18 at red line, FYI.
    Jul 2009
    2,305
    Drop your DAL's a bit in the midrange. I'm around 270 for 24 psi, spikes 25 for a split second than cuts back. Also tapers to 18 psi @6k.
    The more you exceed 24psi, the greater the risk of ring land damage on long hard pulls.
    Senior Tuner BackyardTurbo_FTW's Avatar
    Jul 2009
    East Suckburg, PA
    1,163
    I ended up ditching this. The reading is so erratic that I just don't trust it.
    Jul 2009
    2,305
    Mine looks pretty good, but I think I'll add the original back in to my charts also.
    Feb 2010
    The Desert
    480
    Thanks for your help Tom.
    I've found that this boost PID closely matches my gauge and in most cases as it starts to taper off is almost identical to my other boost PID (courtesy of Tom).
