Results 1 to 1 of 1
Thread: What parameters can I edit?
    Sep 2002
    Chicago, IL
    6,396
    Question What parameters can I edit?
    The million dollar question..
    VCM Edit Screenshots
    Here is just a basic summary of some of the things you can edit with our package. A complete list would be quite lengthy.
    The exact parameter set for your particular application may be different. Due to the number of applicaitons we support, we cannot list all of the supported parameters on a per application basis.
    Engine
    • EGR, Air Pump, COT Enable/Disable and controls
    • Rev Limiters, Idle Speed and characteristics
    • Throttle Follower and Cracker
    • MAF Tables, Main VE and Cranking VE
    • Power Enrich fuel controls
    • Closed Loop/Open Loop characteristics
    • Injectors
    • Spark Advance and Retard
    Engine Diagnostics
    • MAP Error Values
    • MAF Error Values
    • Misfire Values
    • DTC's
    Transmission
    • Shift Speeds
    • Shift Firmness and Time
    • TCC Parameters and Tables
    • C.A.G.S.
    Transmission Diagnostics
    • Trans Slip Test Conditions
    System
    • PRNDL Flag
    • Fan Type Select
    • VATS
    • Fan On/Off Temps
    • A/C Parameters
    Speedometer
    • Speedometer
    • Speed Limiter
    We got this guy Not Sure, ...
