Results 1 to 4 of 4
Thread: Timing for 150 nitrous (table pic)
    Feb 2010
    9
    How does it look
    Im shooting 150, vp on a dedicated at 6 psi, autolite 103, AFR I guess it will be around 12 since Im still figuring out where to settle for a safe start, using microedge to control shot, this is a base start since Ill make change on what plugs says
    stock table
    all inputs are welcome
    Aug 2008
    Shawnee,kS
    81
    I'm not sure what an autolite 103 plug is. But if you were running a TR7 (BR7EF) that's a safe colder plug and had a standalone with all race gas i'd only pull out 3-4 degrees on that shot. I would shoot for 11.5-11.8 afr
    1998 Pontiac Trans Am - 1000+ rwhp street car
    Jan 2010
    47
    also while we are on timing..... got a good question. lets say shoot a 100 dry and 150 wet set up as 2 systems. My question is what would be a good timing and a good afr for 250? give or take 25hp on the systems thanks for imput. I was thinking i am at 28 deg on hp at like 13.3 afr and was figuring maybe 12.0 and like 22 degrees. The reason why 12.0 afr is because of the dry adding fuel when it hits the maf.... thanks a bunch
    Dec 2008
    on the Dyno
    1,825
    You'll want more timing pulled for just a 150 shot. Learn to read the plugs and you'll get the nitrous running well! Most LS1/2/6's that I've tuned for spray will have 8-9* pulled for just a 150 wet shot. Another 100 dry on top of that would probably be at least another 4-5* or so. Reading the plugs will tell you where to set your timing at!
    Located in Central Kentucky
    ShorTuning
