Trying to tweak the VE table per instructions:
Diable MAF,DFCO, and PE interference
Configure VE - LTFT histogram w/ cell hits req'd at 5
Re-set LTFT's
Scan for cells at idle, 2000-4000rpm varying and constant loads
Copy/Paste Special % Multiply in to VE table
....have done this and by the 5th round I noticed the histogram cells in the .08-.12 & 3000-4000 rpm area were not improving closer to zero....10-15 everytime, which was forcing my VE table very high in the 4800-6000 rpm & 20-35 kPa. The last numbers I was showing ranged in the VE table in the 125-140's. What the heck... I changed them before and I got pretty close, but read that re-seting the LTFT's each time was needed...which i did this time and wanted to tweak the tables a bit and not the case. Any experience with this and direction would be awesome. Thanks
