Hey all,
Hoping someone can give me some direction here; bit of a confusing problem.
Car has a 1998 F-Body PCM, on a 347" LS1 w/ a turbo; 2 BAR OS.
When I hook up my IAC, the car will pull the idle up to ~3000 RPM and hang there; I've replaced the IAC and that made no change. I've toned out the leads from the IAC plug to the PCM, all good.
If I manually adjust the IAC, and just leave it unplugged, the car idles and drives just fine. When I log with the RussK config, it shows my IAC counts dropping to 0; there is no change in the idle RPM, though I can occasionally jump into the VCM controls, force it to 0 there and get a noticable RPM drop (bottoms out around 1250 RPM).
I have reset the TPS using the unplug, power on, power off, plug in, method. Readings and voltages are good.
This happened to me last year, and I just unplugged the damn IAC and tuned idle with the throttle blade (using the set screw, blade is undrilled). I rebuilt the car over the winter, put it in, and it was fine the first several hundred miles. All of the sudden, 3500 RPM idle, no tuning changes.
I'm quite confident there are no vacuum leaks; I've checked with propane, verified with my gauges, and the idle behavior when I bypass the IAC is just as expected (and if I plug the IAC hole with a rubber stopper, the car will, obviously, not run).
From everything I can determine, it seems like the PCM is opening the IAC up, then sending commands to close it, but it's not closing. Again, this happens with 3 IACs.
WTF.
