Results 1 to 3 of 3
Thread: Can transmission torque management act as traction control on car that doesn't have o
    Advanced Tuner ALB's Avatar
    Jun 2007
    regina,sk canada
    311
    Can transmission torque management work similar to regular traction control ?
    Anyone useing torque management in this way. Figure could work good on the street at track would turn it off as run there on the et streets but not going to be using them on street that much.
    My car has no stock traction control.
    99 TAWS6 ERL 427 superdeck,AFR 225, LS9 cam, 1.7 yella terras, fluiddampr, fast 90/90,APS Twin turbos LG upgraded turbos,cutout.80 pound injectors, RPM 4l80e ,yank py3400, dana 60, lonnies dual pump fuel system,zex direct port,ron davis rad,ais alc injection
    interceptor guages, eboost 2.
    Other toys 91 race talon turbo awd, 97 talon awd turbo, 2008 Z06
    Dec 2007
    776
    Quote Originally Posted by ALB View Post
    Yes it can. Though relative to wheelspeed based control it is pretty dumb. Simply torque limiting to prevent wheel spin. It does mean you can totally hit it and the ECM manages the throttle.
    Jun 2007
    regina,sk canada
    311
    I think my car is more controllable with this. Not sure will use it at the track likely turn it off but think its not a bad idea on the street.
