Is it safe to modify the settings for Engine - torque Management - general - RPM vs GEAR Maximum torque.
the stock settings were ate 360 for 1st gear.
Yes, it's safe but: You will have traction problems in firstassuming you are FWD with the LS4. You can tailor 1st gear torque settings to minimize spinning but it's more trouble than it's worth.
Should i leave it stock or adjust it to 600 ft lbs toruqe.
Originally i had it at max. but it was not very drivable.
in bad weather.
thanks for your input..
