Thought I would share some research on this TCC/TCM. So far I've been able to determine with HP and another software that PWM is disabled in this tranny. Having said that, I believe the TCC solenoid regulates line pressure based on estimated engine torque. I say PWM is disabled based on the code in the TCM and the lack of a PWM solenoid in the schematic I have. We have found some TCC desired slip tables that are RPM based. I think these tables could play a role in why I don't see max line pressure after lockup. If you monitor the log, you can see TCC pressure rise as TPS increases. I can force lockup with the scanner and get 594psi displayed along with a very aggressive engagement of the TCC. Under a normal WOT run to 120mph the TCC engages in second gear and the pressure reads about 30psi. The pressure gradually rises throughout the run and reads about 104 at the end. TCC slip is around 100rpm until midway through third where is drops to zero and stays there. What is interesting is when I force lockup in second I get 594psi and the TCC slip goes to zero. This clearly shows how tight the stock converter is. I have also run a log with no TCC lock up. The average TCC slip during a WOT run is a little over 100rpm with no TCC line pressure. I think if HP could get us the desired slip tables and more control over TCC line pressure we could make better use of aftermarket converters. If we were to have access to the desired slip tables I believe we could even program in a stall Bill, Chris?? Forgot to mention I see no PWM duty cycle while logging, another reason I feel it does not exist on the tranny.
