My LM1 is set up for 10-20afr 0-5v and I'm getting readings from 9.2afr-19.8 while cruising on my stock 04 gmc truck cruise and light throttle 19.8afr, 100% throttle shows 9.2-10.5 afr this cannot be right?
I have had the truck for quite some time and tried putting the original tune back in when I saw the odd numbers showing up since I am trying to learn I thought I messed something up, but found exactly what I have described.
I have also tried calibrating several times.
How can the wideband read outside the set range?
What could be causing these readings? calibration?
Thanks any info would help!
