Results 1 to 7 of 7
Thread: Changing LM-2 Output defaults
    Does anyone know how to change the default output on a LM-2 to AFR? Everytime I connect the unit, I have to reprogram it to output AFR to HPT.
    Do the settings reset or does the fuel type change to custom?
    If so you may have a ground offset or a low voltage.
    Advanced Tuner omega_5's Avatar
    Aug 2005
    Maidstone, SK
    466
    Quote Originally Posted by JoeyJoeJoe View Post
    Ground the negative signal, it will eliminate the floating voltage.
    ... it's an Innovate quirk.
    Tyler
    The settings for what to output reset everytime I power on the unit. I need to go into the LM Programmer and set it to output AFR and reprogram. Once i do this the LM and HPT look identical. Everytime I open the LM Programmer it is set to output Lambda.
    I dont think it is a ground issue, as even playing with it just plugged into the laptop it does the same thing.
    Aug 2005
    Maidstone, SK
    466
    Ah....
    Yeah, you'll have to use the LM Programmer to change the output AFR, or you can make a custom PID to change values on the input side.
    If the LM keeps resetting, you are probably better off going with the second option.
    Tyler
    cool, thanks
    It's always like that.
    The Lambda output converts to AFR based on the fuel setting,
    you don''t need to select the use AFR bubble each time.
