I am using the AFX WB and I thought I read somewhere that it is best to hook up the analog output signal wire to the EIO connector and to attach the analog output ground to the same place where you are grounding for power, which in my case is directly off of the battery. I cant find it now to verify and I am curious if I am screwing up the readings with it setup this way.
TIA
