Originally Posted by
zippy performance
I think the word "great" here is over used. Not going for an insult, but there is much to be improved on there.
Maybe I should elaborate at some stuff to look at.
Your part throttle shifts are too close together in upshift and downshift.
Your wide open rpm shifts are lower than stock. Because of the tight converter the higher shift point is needed to keep you in the powerband making more power. If I had an LS2 dynosheet at home I'd copy it and outline it in the graph for you.
Your shift timing on the 1-2 shift is increased and yet you have changed the force motor tables to give more line pressure. My only assumption is that you were getting a harsh 1-2 shift which would be caused by the changes made to the force motor calibration. There is no reason to change the calibration on the force motor tables. Lower the shift timing to your actual desired shift time to fix your shifting issue's. If anything you need a shift kit and some servo's, not a jacked up force motor table.
Your shift pressures for the 1-2 are stock pretty much which is suprising. You're better off adding a bit here rather than upping pressure via adjusting the force motor. Your 2-3 table has plenty added which is fine, but your 3-4 is rather agressive.
Adding more on the trans side of things. Something to consider here is that I see no changes at all to the v.e. tables. Not only is the v.e. table important for fueling, spark table, etc., but it's also important to have that correct since the pcm uses info from that table to determine torque output of the motor which in turn assists the computer in deciding what area of your trans tables to use. As you can see pressure, shift timing, etc., are torque based. When the v.e. table is correct your shifting will also improve considerably since the computer will have a better torque reading to decide how much pressure to command, shift timing to work with, tcc pwm to command, etc.
Your TCC part throttle settings have been changed, but don't match the wide open settings. If you were shooting to gain performance you wouldn't want the tcc to lock sooner at wide open, but in fact lock in much later under heavy throttle.
The torque reduction tables are very confusing. Downshift torque reduction is actually more important to keep if you are going to keep any at all since that is the biggest reason for a shortened life in the 60/65/70E's. You can drag race the hell out of them with great success, but street driving with alot of downshifts kills them. The amount you left in there isn't even enough to do anything. The upshift has torque management even at zero torque. At higher torque levels you have less torque reduction than lower torque numbers. That is certainly unusual and commonly only done because of agressive shifts which come from changing the force motor settings.
I'm curious as to why you would raise the idle a bit and yet lower the minimum idle airflow numbers?
I see that the mass airflow calibration is still stock. If you check the stock mass airflow calibration you'll find it is off even with the stock airbox/tube/filter, etc. I'm suprised you haven't modified this yet.
The same goes with the v.e. table. Even on a stock setup you'll find it to be off some. On a modified setup you'll find it to be much further off. Getting this dialed in will help with how well the transmission works, spark tables, throttle transitions, etc.
The power enrichment is set at 1.190 which sets your afr commanded at 12.33:1. This means you're either compensating for a miss calibrated mass air and or miss calibrated v.e. table. You'll make much more power with a considerably leaner afr. Also with E67's and E38 pcm's I wouldn't recomend setting your map requirement for p.e. that high as that can cause big delay's in p.e. coming in. It also can cause problems in higher altitudes to someone copying the tune since they may rarely get that good of air. The tps % on the E67's and E38's are also fussy and it's recomended to keep it as low as you can without having it come in while you're driving around.
If you're looking for a power increase I'd also recomend turning the C.O.T. enrichment off. You've already set the afr fat without the C.O.T. adding fuel. That will just reduce power further.
With the spark correction table under p.e. zero'd out and the current high octane spark table you have there is less timing under wide open than stock in some area's. You should be able to run more timing than what you have there, but you have a great base of what you were after. I'd highly recomend a set of NGK TR6's. I know a colder plug sounds odd, but trust me when I say I've spent alot of time with the LS2's and you'll find that they are no where near as touchy with the timing with the TR6. In fact on the dyno I've picked up 12RWHP on a completely stock LS2 by changing nothing other than the stock plugs to the TR6's and that was on the stock tune at that point.
Your IAT spark table is actually pretty damn good. I would change the multiplier a bit, but decent work there.
Overall don't take what I'm posting here as an insult, but my point is that if people are downloading this to use in their vehicle as a great upgrade, they need to understand it still needs plenty of work. These are just a few pointers to look at for version 3.
