Results 1 to 15 of 15
Thread: Where to Start?
    Nov 2004
    Glasgow, KY
    58
    Where to Start?
    I've scanned my car, and saved my .bin, now what? I've read the help and I couldn't make heads nor tails from it. I know I'm going to get flamed for not searching, but I don't even know what to search for.
    1999 Formula WS6&&ST. 2 GTP Heads, TR224/224, Moser 12bolt&&Full Suspension
    Advanced Tuner Screamn03's Avatar
    Feb 2004
    Vacaville, CA
    832
    Re: Where to Start?
    What do your LTFTs look like? Can you host the .cvs file from the scanner so we can see it? If not email it to me at [email protected] . No one is going to flame you here, don't worry.
    -Michael Rudolph-
    2003 Redfire Cobra
    Eaton Powered to a:
    11.301 @ 129 1.68 60' MT DRs
    11.85 @ 124 1.90 60' street tires
    Nov 2004
    Glasgow, KY
    58
    Re: Where to Start?
    Quote Originally Posted by Screamn03
    How do I get a .CVs file? All I have is a .bin, do I need to record it going down the road? I'm really bad at this.. :-[
    Feb 2004
    Vacaville, CA
    832
    Re: Where to Start?
    You are going to want to start using the scanner to log what is going on while you drive the car. When you are done logging you want to make sure you "scan->export data" which will produce a .cvs file that you can open in microsoft excel to view.
    -Michael Rudolph-
    2003 Redfire Cobra
    Eaton Powered to a:
    Nov 2004
    Glasgow, KY
    58
    Re: Where to Start?
    I'll do it Tomm. my neighbors aren't too keen on me starting my car at 10pm. They complain enough about the dog barking.
    Nov 2004
    Glasgow, KY
    58
    Re: Where to Start?
    I just emailed those to you, thanks for taking time to look at them.
    Feb 2004
    Vacaville, CA
    832
    Re: Where to Start?
    Taking a look at your logs this is what I see:
    While in FTC22 (WOT) your LTFTs are 0. This is good because the computer is not adding any additional fuel based off of LTFTs.
    The car seems to be a little fat WOT. Your 02s read about 950-960. While not totally acurate like a WB02 it still gives you a general indication that the car is running alittle rich WOT. At this point I wouldn't be to worried about it because it's safe and you have some other work to do first.
    I suspect a large amount of IFR (Edit->Engine->Fuel Control->General->Injector Control->Flow Rate vs KPA) scaling due to the high negative LTFTs . Who tuned the car and do you still have the stock .bin file?
    Your timing WOT looks kinda goofy to me.
    3000 3250 3500 3750 4000-5300->where you let off
    31 32 31 30 28.5
    No KR so that's good. Just seems like alot and I don't know why whoever tuned it wanted it to start to decline.
    http://hometown.aol.com/tranzam777/9...11-06-04-2.csv
    http://hometown.aol.com/tranzam777/9...n11-6-04-2.csv
    So I guess the questions I have for you are:
    1)Has the car been tuned?
    2)Do you still have the stock .bin file?
    3)Do you have any codes stored in the computer (use the scanner->tools)?
    4)Anything the car does that you don't like (start funny, surging, ect)?
    -Mike
    -Michael Rudolph-
    2003 Redfire Cobra
    Eaton Powered to a:
    Nov 2004
    Glasgow, KY
    58
    Re: Where to Start?
    -Mike
    (1)I'm not sure if the car was tuned before me or not, as I'm not the original owner nor did I put the cam and heads on the car, so I'm not sure. I took the car to TEA and Brent (tuner) put a basic tune in it there, but at that point I had the MAFT on there. I have since pulled that off and sold it. (2)I do not have the "stock" .bin. (3) I'm getting:
    P0300 - Engine Misfire
    P1637 - Generator L-Terminal Circuit
    (4) It doens't do anything serious, when I first start and it's in closed loop, it runs way rich, and backfires.
    Feb 2004
    Vacaville, CA
    832
    Re: Where to Start?
    You have an email about your P1637 code.
    -Michael Rudolph-
    2003 Redfire Cobra
    Eaton Powered to a:
    Nov 2004
    Glasgow, KY
    58
    Re: Where to Start?
    is there a way to isolate and view the Generator l terminal with HP Tuners? Thanks for looking at my files. So how do I correct the fuel trims?
    Feb 2004
    Vacaville, CA
    832
    Re: Where to Start?
    For right now clear the codes and see if the P1637 comes back. Someone might have done something when they did the H/C install. Something tells me it will come back but start here just to make sure.
    There is a stock '99 .bin file on horrist's site:
    http://www.horist.com/hptuner/
    Download it and start comparing tables to see what has been changed in you .bin, something tells me you are going to find the IFR screwed with. If you could send me a copy of your .bin to my email I'd be happy to take a look at it and tell you what I find. I'll also host it here that way others can comment also. BTW:Where is everyone else ????
    Whatever you do, do not try and flash any .bins you get off of horrist site to your computer. Only flash the .bin you have out of your computer. You can copy and paste tables from .bin to .bin but you can not flash another persons .bin file to your computer. Just a word of caution in case you didn't already know or in case someone is reading this that doesn't already know.
    EDIT:
    99FormulaWS6's Bin
    http://hometown.aol.com/tranzam777/9...formulaws6.bin
    Copy of Stock '99 F-Body .bin
    http://www.transamws6.net/HPTuners/bin/2048137123.zip
    -Michael Rudolph-
    2003 Redfire Cobra
    Eaton Powered to a:
    Nov 2004
    Glasgow, KY
    58
    Re: Where to Start?
    Thanks for taking time out to help me, what could cause the P1637 error? The alternator was just replaced before I bought the car. Sometimes I get a SES and other times I do not, it's one of these. The .Bin is sent, the main spark vs airflow vs WOT looks out of wack to me and I don't even know anything about it.
    Nov 2004
    Glasgow, KY
    58
    Re: Where to Start?
    After looking at my IFR and comparing to the stock .bin the first o number were the only ones that were off everything else was the same. As far as by a "large amount" I'm not sure.
    0 VAC 5 VAC
    Stock- 26.41 26.6
    Mine - 22.63 22.63
    Feb 2004
    Vacaville, CA
    832
    Re: Where to Start?
    Ok, this is what I see comparing to the stock '99 .bin the I posted above.
    MAF:untouched-this is a good thing
    VE:slight low rpm reduction, it's going to need that since you have a good sized cam, this doesn't mean it's optimal but it's going in the right direction
    IFR:just like you stated above, only the first two are messed with->0 & 5 vac. I would say return those to stock values but I'm afraid it's going to lean out you WOT a/f ratio so leave it at this time until I or someone else comes up with a battle plan
    High Octane Spark Table: This looks all hacked to hell, I think you are going to want to start from [s]scratch[/s] stock with this one
    PE: Stock was 1.25 which equals 14.7/1.25=11.76A/F commanded
    Yours is 1.14 which equals 14.7/1.14=12.89A/F commanded
    If you do end up setting the IFR back to stock I would change you commanded A/F (PE) back to 1.25 for a margin of safety. After you see where your A/F ends up I'd work on getting it back to 12.6-12.8ish. Ideally you want your commanded A/F ratio (# in the PE) to match what you end up with at the tailpipe.
    Let me think about this a little and I will get back to you with suggestions.
    -Mike
    -Michael Rudolph-
    2003 Redfire Cobra
    Eaton Powered to a:
    Nov 2004
    Glasgow, KY
    58
    Re: Where to Start?
    Anyone have any insight as to what I need to do here?
