Hey to all,
Whats everyones maps look like at idle? and on decel? and WOT?
I live here in denver, at mile high altitude, and at koeo, i have 84 kpa, (atmosphere), and at idle i have 30 kpa. On decel the map drops down to 14kpa. Tuning with the ve tables is really kinda outta the question now because all my adjustments happen in the 14-45 kpa range. And nothing over.
I have a LS2 out of a 05 gto completely stock except for headers, full 2 1/2" mandrel bent exhaust with x pipe, and exits before the rear tires on both sides. Also have a street and performance air filter which has a built in MAF and pcv conn.
I attached 2 logs, 1st had the stock gto tune in it, the second had a little tune to it. I used the method from the hp tuners help section for the tune.
Again, just wanted to see what others with the LS2 had going on as far as map sensor readings.
Thanks for any and all responses!!!!
