Results 1 to 3 of 3
Thread: LM2 issue
    Oct 2007
    346
    LM2 issue
    Well, tried hooking up the wideband for the first time.
    Tried hooking and green and light-green wires to pin 1, and yellow wire to pin 5 (ground), however nothing seems to appear on the scanner at all.
    I did add the aux inputs in the bottom of the table view but it reads a dead value, something like 15, or 10, its obviously not getting any signal from the wideband.
    what have I missed?
    Any ideas??
    Advanced Tuner blownbluez06's Avatar
    Jan 2008
    Forney, TX
    982
    If it's like the LM1, you need to go in to the LM programmer and program the output to the desired scale. How did you configure the EIO?
    Hsquared racing engines RHS 427, Procharger F2, Moran Billet Atomizer injectors, Alky Control,Mast LS7 heads, Nitrous outlet kit,Tilton quad disc clutch, DSS shaft, RKT56 ZR1 trans, RPM Quaife diff. Built and tuned by yours truly.
    Sep 2009
    13
    program the lm2 for a afr 10-20 at 0-5 volts and choose the lm1 preset or leave the lm2 at a factory setting and choose the lc1 preset. mine works both ways. the lm2 and lc1 have the same factory presets.
