I have a 2 bar os on the pcm now. I need to convert to a 3 bar for more boost.
I have attempted to do it thru the os function with no success.
Does the PCM need to be reflashed to stock?
Open your stock operating system & apply 3 bar, then write entire, done.
I am having this same problem, but the 2 bar was already applied to the car by someone else so I do not have the stock operating system. What would my options be to convert it to a 3 bar operating system?
by no means am i sure but from what i have read you would have to get a stock OS from repository. This would cost 2 credits unless you have your year model unlocked. then you would have to use 2 more credits for the 3 bar. hope this helps.
i hope i am correct, surely someone else will chime in.
gen 3 custom operating systems are os mod locked ie tech 2 cannot flash to them.
correct
