Results 1 to 12 of 12
Thread: Converting to 3bar from 2bar
    Feb 2007
    19
    I have a 2 bar os on the pcm now. I need to convert to a 3 bar for more boost.
    I have attempted to do it thru the os function with no success.
    Does the PCM need to be reflashed to stock?
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    Open your stock operating system & apply 3 bar, then write entire, done.
    Feb 2007
    19
    Thanks Bill
    Feb 2012
    1
    I am having this same problem, but the 2 bar was already applied to the car by someone else so I do not have the stock operating system. What would my options be to convert it to a 3 bar operating system?
    Aug 2012
    3
    Quote Originally Posted by lsx1 View Post
    wondering the same thing
    Jul 2013
    18
    Quote Originally Posted by miller456 View Post
    Same here
    by no means am i sure but from what i have read you would have to get a stock OS from repository. This would cost 2 credits unless you have your year model unlocked. then you would have to use 2 more credits for the 3 bar. hope this helps.
    i hope i am correct, surely someone else will chime in.
    HP Tuners Support
    (foff667)
    28,265
    Quote Originally Posted by prostreet1967 View Post
    You are correct.
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Flash back to stock with a Tech II. That would be cheaper than using 4 credits for a tune from the repository (that might not be stock) plus the enhanced OS, as you already used 4 credits for your PCM.
    Russ Kemp
    HP Tuners Support
    (foff667)
    28,265
    gen 3 custom operating systems are os mod locked ie tech 2 cannot flash to them.
    Dec 2005
    Regina, Sask.
    4,214
    So Hp Tuners can write entire with a stock file, were as a Tech II can't? Even though the custom OS isn't tuner locked?
    Russ Kemp
    HP Tuners Support
    (foff667)
    28,265
    correct
